Date/Time: Wed, 27 Nov 2024 16:30:45 +0000
TPO Chart
View Count: 1049
[2014-09-20 15:47:25]
User95521 - Posts: 53
I have some questions about the TPO chart:
1. How to increase the date range in file?
It now could only load 2014-03-12 to 2014-09-19.
2. To merge the TPO chart, What is the maximum number of days we could merge it?
I try to merge 60-90 days TPO chart and compare it with CQG market profile data.
Some pairs is 100% the same with CQG, ie. AUDUSD.
But some pairs is different from CQG to a large extent, ie. USDCAD.
Could you please tell me the reason?
Thank you!
Best Regards!
[2014-09-22 21:03:08]
1. Refer to this section here about the Date Range in File:
https://www.sierrachart.com/index.php?page=doc/doc_ChartSettings.html#DateRangeInFile
2. There is no limit to the number of TPO Profiles which can be merged together.
If you notice a difference comparing TPO Charts to another program, then the difference would be with the underlying data. So you then have to compare the underlying data between the two sources to see where there are differences.
To see the underlying data, remove the TPO Profile Chart study from the chart.
