Date/Time: Mon, 21 Apr 2025 17:55:42 +0000
Display Globex opening range on RTH-only chart
View Count: 105
[2025-02-17 03:49:32] |
DODSurf - Posts: 14 |
Hello, I use 10 min charts displaying regular trading hours only. Is there a way to automatically display the London 1 hour opening range(high/low)? Thank you |
[2025-02-17 17:11:51] |
John - SC Support - Posts: 39380 |
You would need a chart that has the hour you want in it for the London Opening. Then use the "High/Low for Time Period" to get the Opening Range you want. Then use the "Study/Price Overlay" to overlay that to your other chart. Refer to the following: High/Low for Time Period Study/Price Overlay Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
