Date/Time: Mon, 21 Apr 2025 23:36:10 +0000
Static Vs. Persistent Variables
View Count: 151
[2025-02-17 03:07:35] |
User509533 - Posts: 73 |
Under a chartbook, if multiple charts are running the same study (xyz.dll) with a persistent variable P, any of those charts can modify P. To ensure each chart has its own separate copy of P, would using a static variable be the right approach?
[2025-02-17 07:34:13] |
Sierra_Chart Engineering - Posts: 19290 |
A static variable would mean that every instance of the study is using the same variable. Use ACSIL persistent variables for each instance of the study to have its own variables: ACSIL Interface Members - Functions: Persistent Variable Functions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-02-17 08:41:21
