Date/Time: Mon, 21 Apr 2025 23:33:10 +0000
How do I delete
View Count: 139
[2025-02-16 22:03:37] |
SomeRandomUser - Posts: 150 |
I'm trying to get rid of unwanted presets and go back to default settings. Is there a way to do this? I have one preset I like and want to get rid of all the others, but don't want to have to manually go through to set it up again on a new Sierra Chart install. Thank you. |
[2025-02-16 23:17:15] |
Sierra_Chart Engineering - Posts: 19290 |
What preset are you referring to? We need to know specifically.
[2025-02-17 03:34:52] |
Sorry, half of what I had written was deleted (not sure why) and I didn't check the post after publishing it. Global Settings->Graphics Settings - Global The pull-down box with 20 graphics settings that you can store/load. I'm trying to see if I can reset this, or at the very least delete individual entries. I know that you can re-save them but I'm not sure if there is a way to revert back to default/unused. Thanks. Date Time Of Last Edit: 2025-02-17 03:36:12
[2025-02-17 07:32:53] |
No there is not a way to reset those. The only thing you can do is reset the global configuration of Sierra Chart entirely: Resetting Sierra Chart to a Default State / Restoring Backup Global Configuration File Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-17 09:24:21] |
Thanks.
