Date/Time: Mon, 21 Apr 2025 17:55:43 +0000
[Programming Help] - my cart has gaps where trading view doesnt
View Count: 140
[2025-02-16 19:39:58]
keanufrederic - Posts: 5
i just want continuous charts for the es. but i have random 30min - 3.5hr gaps and i have no idea why
[2025-02-16 20:13:28]
you can see my chart has a ton of gaps where tradingview does not
imageScreenshot (139).png / V - Attached On 2025-02-16 20:12:57 UTC - Size: 1.14 MB - 41 views
[2025-02-17 16:39:22]
John - SC Support - Posts: 39380
For one thing, your Session Times are incorrect. Your main session times cover a 23 hour period, which is fine, but you then specify a separate Evening session. You either need to change your main Session Times to not include the Evening Session, or you need to not use the Evening Session.
This could affect the way your data looks, but we would be surprised if it is for what you are seeing.
If you still have a gap after setting the Session Times correctly, then follow these instructions to redownload data starting from the earliest point in which you have a problem:
