Date/Time: Mon, 21 Apr 2025 23:27:28 +0000
Average True Range - Documenation Error?
View Count: 144
[2025-02-16 14:42:46] |
user_xyz - Posts: 467 |
I've been using the ATR for years on intraday charts and just noticed this while double checking some data Is this correct? This study only functions properly on a Historical Daily chart. A Historical Daily chart can be opened with File >> Find Symbol >> [select symbol] >> Open Historical Chart.
Average True Range *Last modified Sunday, 29th January, 2023. Date Time Of Last Edit: 2025-02-16 14:43:37
[2025-02-17 16:25:02] |
We do not see any reason why there would be a problem using this on an Intraday chart. We think that note may be from an earlier implementation and was never updated. Just be aware that the Average True Range uses the same formulas as the "True Range" study, which is defined here: True Range For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
