Date/Time: Mon, 21 Apr 2025 18:16:46 +0000
Profile right of last bar
View Count: 186
[2025-02-16 11:05:42] |
gz6969 - Posts: 30 |
Hi, is it possible to place a 3 week profile at the right of the last bar as it is in Smashelitos chart(see the orange arrow in the left chart)? In my chart at the right the 3 week profile overlays always the last bar of the chart. Or does he use copy & paste ;-) Date Time Of Last Edit: 2025-02-16 11:18:58
[2025-02-16 20:12:03] |
Tr00pz - Posts: 20 |
You need the following settings set to 'Yes' on both Volume by Price studies: Right Align Volumes Bars Allow Side-By-Side Profiles on Right Side Align To Far Right The order they are listed in study summary determines which will show on the right or left side. |
[2025-02-16 21:32:01] |
Thank you TrOOpz!. Now the 3 week profile is splitted from the bars. But how can I move it a bit to the right now? Only the candles are moving when I move the mouse right or left. There is no fill space. https://www.sierrachart.com/image.php?Image=173974108499.png Date Time Of Last Edit: 2025-02-17 09:58:12
[2025-02-17 16:43:20] |
John - SC Support - Posts: 39381 |
Check how you have the following Input set: Volume By Price Study: Use Defined Width for Side-By-Side Profiles on Right For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-17 20:10:13] |
Thank you , I've found the solution: the 3 week profile was on the 10th position in the study list. The large profile was on position 4. After I've moved it up to position 5 the profile was immediately positioned next to the large one.
