Date/Time: Mon, 21 Apr 2025 23:27:29 +0000
Simple Feature Request. Historical Close based on Intraday Close
View Count: 162
[2025-02-15 21:31:44] |
barzay.bavno - Posts: 20 |
Hello. I presume what I am about to ask has already been asked in the past, and it is probably a bit annoying, but I am of the opinion that it`s inappropriate for a proffesional platform like Sierra not to have it. Entry Level Platfrom like Trading View have alrealdy implemented it. May you please add the simple option of the Close Price on the Historical Charts to be based on the Intraday Close (instead of the Settlement). And YES, I am aware that you can download intraday data and modify it to show a day worth of Price Action, but it is extremely inefficient and although I managed to tweak it for A Day TimeFrame Chart, my attempts for the Weekly have all been unsuccessful. Cheers. |
[2025-02-16 02:23:50] |
Sierra_Chart Engineering - Posts: 19290 |
There is zero possibility and zero consideration of this, and there is no technical way to do this. It is out of the question. We do not even have the ability to control that data. We will not say anything more. And this does not make Sierra Chart unprofessional in any way. The official data uses the settlement price. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-02-16 02:24:36
[2025-02-16 19:32:56] |
Okay :) It is what it is. Do you have any recommendations on how to modify the chart so the intra-day data is shown in exact 1 week time period ? |
[2025-02-16 23:40:52] |
Refer to: Chart Settings: Weekly Bars (Time Specific Bars) Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
