Date/Time: Mon, 21 Apr 2025 23:33:12 +0000
[User Discussion] - Zig Zag does not work on inside reversals
View Count: 95
[2025-02-15 16:20:33]
User360283 - Posts: 514
Zig Zag works on New Day Highs and Lows ONLY. It does not trigger on "inside" reversals. Meaning When a reversal on an up trend occur just below the previous reversal or just above the previous low ZigZag does not alert.
Friday Feb 14 the E Micros was inside the day's high and low and reversed when nearing the day's hig and lows several times BUT Zig Zag never alerted!!
Is this a setting issue or a ZigZag problem?
[2025-02-15 18:31:00]
JohnR - User831573 - Posts: 330
It could be two inputs. One is the # of bars between H-L , the other is amount of movement needed in price.
Also, I would reread the Calculation Mode selected, to see if it behaves the way you are expecting.
Hope this helps.
JohnR
