Date/Time: Mon, 21 Apr 2025 23:33:13 +0000
chart interval update not as fast as DOM
View Count: 106
[2025-02-14 17:52:40]
User454729 - Posts: 22
Hi there,
I have set my chart at 10ms update interval but the price update (upticking and down ticking) is lagging the DOM, which is also set at 10ms. What else can I do to have the chart price update as fast as the DOM. Thank you.
[2025-02-14 19:43:42]
John - SC Support - Posts: 39395
The general information on performance improvements is at the following link:
High CPU Usage | Inactive User Interface | Poor Performance | Long Time to Load Chart Data | Charts Reloading Often
But since the Chart has more information on it, it may simply be needing more than the 10ms to update as opposed to the Trading DOM. If you want to see for sure, remove all studies from the Chart and set the "Chart >> Graph Draw Style" to "Blank". This will limit the updates needed for the chart and you should see more comparable updates.
