Date/Time: Mon, 21 Apr 2025 17:46:50 +0000
Chart Value Window
View Count: 149
[2025-02-14 16:24:50]
nicktrader - Posts: 748
What can be the reason that in picture #1 Open and Close time of the candle is displayed in picture #2 only Open (please see pic)
I have used two different copies of SC, but always the same chartbook.
Many thanks
imageChart Values.png / V - Attached On 2025-02-14 16:24:09 UTC - Size: 22.33 KB - 42 views
[2025-02-14 22:58:21]
Sierra_Chart Engineering - Posts: 19289
One of the charts is maintaining the ending time of chart bars. This is not always maintained in a chart. It depends upon studies.
[2025-02-15 02:23:27]
"It depends upon studies." I am with you. But as I said."...two different copies of SC, but always the same chartbook..." I didn't change anything in the chartbook.
Is it possible to "cut" the ending time of chart bars to see only the starting time in the chart value window?
[2025-02-17 23:44:13]
No that is not possible.
[2025-02-18 04:56:02]
I have found the “culprit”. It is the “VbP” study. Is there a way to display only the start time of the candle?
VbP is in every chart, because I use it to display the IntraDay Value Area. Only here I can limit the number of days.
Date Time Of Last Edit: 2025-02-18 04:56:38
