Date/Time: Mon, 21 Apr 2025 23:30:20 +0000
sierra charts portal information is true or not
View Count: 129
[2025-02-14 15:34:51]
User511513 - Posts: 5
in your portal i see this :(((( Can Other Programs Use the Trading Connection and Data Feed?
[Link] - [Top]
Yes, they can use the DTC Protocol and connect to the DTC Server in Sierra Chart. )))).
I believe this to be at true statement , is this true or not, or what is that i do not understanding of maybe doing in the wrong way with my script data request functions ?
[2025-02-14 17:42:18]
John - SC Support - Posts: 39395
It half true and half false (at one point it was true, but exchange rules changed).
You can use the DTC protocol as a trading connection between systems. But you can NOT use the DTC protocol for the data feed (the exchanges do not allow this).
[2025-02-14 17:57:39]
do i have any option/way to use sierra charts dat with my scripts ?
[2025-02-14 19:46:44]
You can access the data and information within Sierra Chart through our ACSIL interface. Refer to the following:
Advanced Custom Study Interface and Language (ACSIL)
And you can export the data from the system and access the files. Refer to the following:
Edit Menu: Edit >> Export Bar Data to Text File
You definitely cannot access the real-time data outside of the Sierra Chart program.
If the above does not answer your question, then we would need more information on what you are trying to do.
