Date/Time: Mon, 21 Apr 2025 23:36:06 +0000
Trading Locked Alert Sound Request
View Count: 89
[2025-02-14 15:27:39] |
cesium - Posts: 129 |
Hello Support, I looked in documentation and in global settings - general settings - other alerts for some option for a trading locked/unlock toggle or individual sound alert, if this isnt an option, can it be requested? thank you Date Time Of Last Edit: 2025-02-14 15:27:59
[2025-02-14 18:32:08] |
We have added a new study named "Trade Menu Status" that exposes the state of "Trade Simulation Mode On", "Trading is Locked", and "Chart Trade Mode On" in 3 different subgraphs of the study. This will be available in the next Pre-Release (v 2741). You can then reference the subgraph for "Trading Is Locked" and set an alert based on the status. For instance, to check if "Trading is Locked" is enabled your Alert Condition would look like the following: =ID1.SG1 <> 0 You would then need a separate alert condition for when "Trading is Locked" is disabled, which would be the following: =ID1.SG1 = 0 For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
