Date/Time: Mon, 21 Apr 2025 23:33:12 +0000
Momentum Trading
View Count: 131
[2025-02-14 13:03:10]
bobstone249 - Posts: 34
Hi John,
Is there a study which exists to measure the speed at which price is moving in a market (i.e. how quickly the market is moving from one price point to another)?
[2025-02-14 15:47:25]
cmet - Posts: 690
There are probably more momentum studies than any other type.
If you're using time based charts (ie: 5 min), just use the size of the bar.
For non time based bars (ie: range), take a look at Bar Duration in Numbers Bars Calculated Studies.
Date Time Of Last Edit: 2025-02-14 15:57:47
[2025-02-14 17:52:02]
John - SC Support - Posts: 39395
There are also the "Volume per Second", "Ask Volume per Second", and "Bid Volume per Second" subgraphs in the "Numbers Bars Calculated Values" study.
