Date/Time: Mon, 21 Apr 2025 23:27:26 +0000
I paid for the wrong service
View Count: 113
[2025-02-14 02:31:19]
User198456 - Posts: 3
Today is my first day trying to sign up with Sierra Chart.
I accidentally signed up for Integrated Advanced $46/month. I was supposed to sign up for the integrated standard sierra chart service packaga 10.
Do you know if it's possible to change this and only be charged $36/month?
[2025-02-14 04:20:32]
Sierra_Chart Engineering - Posts: 19290
To change your Sierra Chart Service Package, select "Help >> Account Control Panel" on the Sierra Chart program menu. On the displayed webpage, click on the "Set Service Package for Renewal" link.
Or go to this page:
https://www.sierrachart.com/UserControlPanel.php?page=ServicesActivation
You will need to login if you are not currently logged in.
In the "Available Services >> Choose Usage Time Service Package" frame, select the Service Package that you want to set your account to. Press the "Set" button.
The remaining service usage time on your account will be adjusted based upon the cost of the package you are changing to. If the new package is a higher-priced package, then the usage time will be reduced due to the higher price.
There is no charge for changing your Sierra Chart service package. Only your Sierra Chart account usage time ending date is adjusted.
When changing between Sierra Chart Service Packages, the usage time ending date on your Sierra Chart account is adjusted based upon the price differences between the package you are changing from and the package you are changing to.
When changing to a higher priced package, your usage time ending date will be brought back closer in time. When changing to a lower-priced package, your usage time ending date will be brought forward further out in time.
