Date/Time: Mon, 21 Apr 2025 23:27:32 +0000
Where can I find the default Order Rate Limit?
View Count: 90
[2025-02-13 21:32:08] |
ATEX - Posts: 25 |
Hi, Where can I find the default Order Rate Limit setting? Under Account settings there is "(0=Use Global)", but I can't find the "Global value". Also, what Order Rate Limit can I have with Teton Order Routing? Best, A |
[2025-02-13 21:56:50] |
This is something your broker sets. You need to ask them what it is set to for your account.
