Date/Time: Wed, 27 Nov 2024 15:33:40 +0000
User Email Questions
View Count: 1013
[2014-09-19 19:20:09]
Sierra Chart - Max - Posts: 5731
1.
Would you be able to explain to me how to add OHLC lines from the
previous session to the current session ? I already have the previous
session's close on my chart. I need to add the OHL lines to my chart. I
would also like to add it for the past month as well.
2.
Trying to place a rectangle over a candle. If I put the rectangle over
just the candle, it also moves over the candles next to it.
If I then left click and move the candle it "snaps" to half of the
candle.
If I then try and left click, and approach it from the left side of the
candle instead of the right side to adjust, it moves it half the other
way.
Somehow there is a 'snap' feature that needs to be disabled.
I just want to place the rectangle over the candle, not the ones next
to, but exactly over the candle.
I am fairly certain there must be a 'snap' feature turned on that I need
to turn off.
Sierra Chart Support
[2014-09-19 19:40:42]
1. Use the Daily OHLC study which is documented here:
http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s137
It can be set to display the Open, High, Low, Close lines for prior day on the current day.
For the past month you will want to use the Period OHLC - Variable Period study which is documented here:
http://www.sierrachart.com/index.php?page=doc/doc_TechnicalStudiesReference.html#s294
[2014-09-19 19:42:07]
2. We think we understand what you are referring to and this is not supported.
You will not be able to create a visible rectangle over a single candlestick. It will need to span 2 candlesticks.
