Date/Time: Mon, 21 Apr 2025 23:30:23 +0000
DOM - Recent Bid/Recent Ask Historical Values
View Count: 120
[2025-02-13 02:13:03]
adharamd - Posts: 1
Good evening - I have attached 2 screenshots, one labeled 'DOM Good' and one 'DOM Bad'. The latter is my current DOM and I'm trying to figure out what configuration/setting change I need to make so that the Recent Bid/Recent ask stoers the historical values at all prices there when it was last traded there.
I believe there is a setting to replace it when there is a new price there, and I have that set to 0 ms, but it seems like it's not storing the rest. I've tried looking for answers in other forum threads to no avail.
Any information will be greatly appreciate.
Thank you
imageDOM Bad.png / V - Attached On 2025-02-13 02:09:01 UTC - Size: 34.74 KB - 32 views
imageDOM Good.png / V - Attached On 2025-02-13 02:09:07 UTC - Size: 236.77 KB - 34 views
[2025-02-13 10:37:36]
Sébastien - Posts: 58
You have 3 settings to check to make sure the Recent Bid/ask collumns don't reset :
- Global Settings => Chart DOM Settings => Reset Recent Bid/Ask Volume on Bid/Ask Change => NO
- Global Settings => Chart DOM Settings => Recent Bid Ask Volume Timeout in Milliseconds => set it to a very high number like 10000000
- Chart Settings => Market Depth => Clear Recent Bid Ask Volume Inactive Time in Milliseconds => set it to 0
[2025-02-13 15:26:13]
John - SC Support - Posts: 39395
It sounds like you are wanting to use the "Current Traded Bid/Ask" columns rather than the "Recent Bid/Ask" columns.
The "Recent Bid/Ask" columns reset the value at a price level when the trading moves away from that price and then moves back again. The "Current Traded Bid/Ask" columns do not reset, they continually accumulate. Refer to the information at the following two links:
Global Trade Settings Windows: Recent Bid Volume - Left/Center/Right Aligned
Global Trade Settings Windows: Current Traded Bid Volume - Left/Center/Right Aligned
