Date/Time: Mon, 21 Apr 2025 23:33:14 +0000
Bracket Order
View Count: 127
[2025-02-13 00:06:36]
Oxcap - Posts: 73
Hi Support,
I am using bracket orders for entries. I have one SC instance using Topstep (Rithmic) data and one SC instance using Teton with AMP. I have attached two pictures of entries with OCO stop order labeling to help explain my question.
With the Topstep picture, you will see that the stop order is set at 6054.5. S|S(6054.5)|Open
With the AMP picture stop order you will see there are two (2) different numbers. The correct number is 21672.75 which is showing 14.5pt or 29.00 stop. My question is how can I remove the first part "B(Stoplmt(21687.75)? I tried to mirror my trade> chart trade settings with Topstep SC instance but didnt work.
Can you advise?
imageTopstep OCO.png / V - Attached On 2025-02-12 23:54:41 UTC - Size: 5.64 KB - 32 views
imageAMP OCO.png / V - Attached On 2025-02-12 23:54:47 UTC - Size: 12.75 KB - 28 views
[2025-02-13 14:53:14]
John - SC Support - Posts: 39395
The reason for what you are seeing is that the CME Group changes Stop orders into Stop-Limit orders. Refer to the following:
Order Types: Stop Orders on the CME
And the reason you are only seeing this with Teton is because the Teton orders are actually going to the exchange, but with TopStep it is a Rithmic evaluator and not the real exchange.
