Date/Time: Mon, 15 Dec 2025 09:28:34 +0000
Extend Bar Value Until Future Intersection
View Count: 458
[2025-02-12 23:11:02]
italiantrader93 - Posts: 5
I’m using this indicator on a 30 min chart. I then use study/price overlap at. I constantly have to recalculate the chart. Also it would be nice to have an input where we have the option to delete touched lines. I’m using highs and lows in the 30 min. When I go to my tpo chart and split suboerionds the lines don’t stop when touched. If I press recalculate they do.
[2025-02-13 14:47:33]
John - SC Support - Posts: 43443
This is being overlaid to a TPO chart? If this is the case, then we are surprised that it works even if you recalculate. A TPO chart does not have the same concept of bars like a standard chart, this is why many studies do not work on it. In general, lines that are extended until future intersection will not work well with a TPO chart because of the lack of bars.
[2025-02-13 19:07:51]
Thank you for the reply. Yes it does work. I just had to play with the settings a little. Anyway I understand it can’t be done with tops. Do you know any works around to get what I’m looking for?
Date Time Of Last Edit: 2025-02-13 19:09:23
[2025-02-13 19:25:21]
There are no workarounds for the TPO chart.
If this is for another chart type, then let us know.
[2025-02-13 19:30:26]
Unfortunately I needed it for the tpo. I will try and make it work with bars chart. Will you guys consider the request of making the lines that already intersected disappear (Extend Bar Value Until Future Intersection indicator)?
[2025-02-13 20:10:45]
We take all requests, but we cannot say when we would get to any particular item.
[2025-02-13 20:19:41]
ok thanks
