Date/Time: Sat, 26 Apr 2025 15:40:47 +0000
[User Discussion] - Trade Exit Optimization on Actual Historical Trades with Tick Level Backtesting
View Count: 1503
[2014-09-19 19:01:07] |
User46601 - Posts: 2 |
Hi everyone - I've been searching around google and this forum for a specific answer and am having some difficult, so thought I'd post to get some feedback on where best to research. Situation --- I have about 200 actual trades that occurred through the Sierra Charts platform (connected to Interactive Brokers brokerage and an IQFeed data stream) over the last year. These trades were performed on 1 instrument - the futures contract ES (E-mini S&P 500). My goal is to find out if I would have been more profitable with different types of exit strategies. I'd like to answer the question, "if I had used a larger profit target, or a smaller stop loss, would I have been more profitable over this set of 200 actual historical trades?" Is this possible in Sierra? Documentation seems to point to yes, but I am unsure of the high level steps to do so: http://www.sierrachart.com/index.php?l=doc/doc_Backtesting.php#DifferencesBackTestRealTime Thoughts? |
[2014-09-29 18:03:13] |
There is no function in Sierra Chart which will automatically tell you this. You would have to create a trading system that will duplicate your trades, which we think would be impossible and then run various back tests with different parameters and look at the results of each one.
[2014-09-29 18:09:18] |
Futures Operator - Posts: 239 |
I have wondered the same thing, and wonder if it could be done by recording the last known stop price, at the time of exiting a trade, and then updating an added field in the Trade Activity Log when that stop price is hit, and how far price ran in your favor, before that happened.
[2014-09-29 21:57:40] |
User021827 - Posts: 174 |
hi Dont you need optimization software for that ? shane |
[2014-09-30 12:21:26] |
vegasfoster - Posts: 444 |
I am pretty sure you can create a custom study that would read an external file containing your trades and enter/exit on those points. Unfortunately, this would be beyond my abilities. Fortunately, I am pretty sure you could also do this easily with a spreadsheet trading system by creating a table of your trades on one tab and adding formulas to each row evaluating whether the trade time is straddled by A3 and A4 then return +1 if buy or -1 if sell, e.g. if(and(sheet1!A3>A3, sheet1!A4<A3), 1, if(and(sheet1!A3<A3, sheet1!A4>A3), -1, 0)) Assuming your trade time is in sheet2 column A and the formula to evaluate is in sheet2 column Z. Then in K3 enter formula to buy whenever sum of sheet2 column Z is 1 and sell in M3 whenever -1, e.g. =if(sum(sheet2!Z:Z)=1). Probably not work out this simple and some kinks to get through, but this should get you started in the right direction. If you need more help, you can also contact the master at http://sawtoothtrade.com/tag/tomgilb/, if he doesn't respond here. |
[2014-10-01 02:13:51] |
Thanks for all the responses everyone. It really amazes me that there is no straight forward way to analyze your own trades to tick level resolution - it seems to be a rather hard problem. Excel is a possibility, but would require an annoying amount of programming. I'm just surprised I can't seem to find a trading platform which natively does this (even paid ones). vegasfoster, thanks for the tip in the right direction. I will consider a system like that if I can't get any other platform to work. Cheers. |
