Date/Time: Mon, 21 Apr 2025 23:36:08 +0000
I’m having issues downloading sierra chart
View Count: 114
[2025-02-12 18:41:28] |
User724793 - Posts: 2 |
Hi there, I’m having issues downloading sierra chart.
Private File |
[2025-02-12 19:35:33] |
Sierra_Chart Engineering - Posts: 19290 |
Looks like it is successful other than creating the desktop shortcut. To run Sierra Chart go to C:\SierraChart and run SierraChart_64. You can also install Sierra Chart with the zip installer: Software Download: Sierra Chart Zip Installer Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-02-12 19:35:52
[2025-02-13 15:00:27] |
Hi the issue is , when I try to load up my footprint chart on sierra chart,it all blank is doesn’t load up the chart
[2025-02-13 16:09:16] |
If you are using a MAC computer, then refer to the following: Software Download: Using ARM Version for Apple M-series CPUs For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
