Date/Time: Mon, 21 Apr 2025 23:36:09 +0000
Force certain time incrments on time axis
View Count: 92
[2025-02-12 17:08:54]
gammamale - Posts: 4
Hi Support, is it possible to force the time axis to display the time in increments of our choice? For example on a 1 minute chart can we force it to write the minute only at 9:30, 9:35, 9:40... etc (while keeping it as a 1 minute chart with all 1 minute bars)?
Thank you
[2025-02-12 17:51:47]
John - SC Support - Posts: 39395
There is no control over this. The time increments are drawn at the best possible spacing given what is available.
[2025-02-12 19:04:34]
OK thank you, is there a way to display a grid on the chart on certain intervals? Because for example I dont want to hunt around for the 9:30am candle and try to discriminate it from the 9:32 candle and the 9:28 candles
Edit nvm I found it in Chart Settings > Grid > Vertical Grid Interval and it does put the grid on sensible time boundaries that stay the same, very happy. BTW these are not filled out in the documentation Chart Settings: Vertical Grid Interval Type (Chart >> Chart Settings >> Grid menu)
cheers
Date Time Of Last Edit: 2025-02-12 19:16:43
