Date/Time: Mon, 21 Apr 2025 23:27:30 +0000
Opening a chart from the quoteboard
View Count: 88
[2025-02-12 16:35:39]
User109115 - Posts: 51
Hi. When I do this I get a 1 minute chart with no studies. Is it possible to set the default chart type to be opened from the quoteboard? Thanks
[2025-02-12 17:48:25]
John - SC Support - Posts: 39395
There is not a way to set the default chart type that opens from the Quote Board. There are some items you can control in terms of the default chart type when you open a new chart, which is what the Quote Board option for "Open Chart" is doing. Refer to the following regarding these options:
Chart Settings: Save Days to Load, Intraday Bar Period, Graph Draw Type as Default (Chart >> Chart Settings >> Chart Data >> Chart Data menu)
Study Collections: Automatically Applying a Study Collection to New Charts
The other option is to not open a new chart, but to link the Quote Board to an existing chart that is setup the way you want. Then the symbol will be applied to that chart. Refer to the following:
Getting Quotes: Changing Symbol of a Chart or Trade DOM
[2025-02-12 18:00:30]
Thanks!
