Date/Time: Fri, 20 Sep 2024 06:29:10 +0000
Request for extension
View Count: 890
[2014-09-19 17:51:34] |
User37129 - Posts: 15 |
Hi there I would like to have my SC trial extended, since i am backtesting a new algo. Thank You very much budfox |
[2014-09-19 18:24:20] |
Sierra Chart - Max - Posts: 5662 |
Your account has been activated and/or reset. A restart is necessary if Sierra Chart is already running. Exit the Sierra Chart charting and trading software by selecting "File >> Exit". Open Sierra Chart through the icon on your desktop or through the desktop Start menu. After your Sierra Chart usage time ends, you need to pay for additional usage time through "Help >> Add Usage Credit". Sierra Chart Support |
[2014-09-23 17:11:57] |
How long will this extension be for?
[2014-09-26 03:48:02] |
We show the ending date as 2014-09-28.
