Date/Time: Mon, 21 Apr 2025 23:30:19 +0000
Teton Order Routing Not Working with stage5/Dorman
View Count: 103
[2025-02-12 15:38:28]
Reiatsuu - Posts: 1
I was wondering if there is a different way to connect to sierra chart if I have a stage 5 account. I used to use Dorman as the clearing firm, but now when I try to connect it says Error: No accounts assigned. I was wondering if this has anything to do with Stage 5 being purchased by a different firm. Is there a new to to connect or new settings to use?
Thank you,
[2025-02-12 16:06:52]
John - SC Support - Posts: 39395
You do not need to change anything due to the buyout of Stage 5. Since you are getting that error, you need to talk to your broker about it and see if they have done something with your account.
[2025-02-12 16:09:26]
Sierra_Chart Engineering - Posts: 19290
Refer to:
Important Notice - Resolving: No trade accounts assigned
