Date/Time: Mon, 21 Apr 2025 23:27:31 +0000
Last in First out issue
View Count: 115
[2025-02-12 15:17:34]
John421 - Posts: 4
I did a search for this but did not find any answer that fix this issue for me.
I have my chart settings set to Use Last In First Out Fill Matching (Chart >> Chart Settings >> Trading menu)
and Include Chart Trade List in Trade Statistics for Charts Window = YES
SC will still exit the first fill and not the last.
imageScreenshot 2 2025-02-12 091916.jpg / V - Attached On 2025-02-12 15:10:57 UTC - Size: 139.88 KB - 32 views
imageScreenshot 2025-02-12 092020.jpg / V - Attached On 2025-02-12 15:11:06 UTC - Size: 220.01 KB - 31 views
[2025-02-12 16:12:57]
Sierra_Chart Engineering - Posts: 19290
You are not using the right setting. This is the right setting to use:
Chart Settings: Use Last In First Out Fill Matching (Chart >> Chart Settings >> Trading menu)
[2025-02-12 18:49:05]
John421 - Posts: 4
I found it
I had to change setting
Use Last In First Out Fill Matching (Chart >> Chart Settings >> Trading menu) = Yes
The other one is to move you fill price marker
Thank you
