Date/Time: Wed, 19 Mar 2025 02:22:28 +0000
Sierra charts ES keeps frezzing
View Count: 180
[2025-02-12 14:09:48]
User175867 - Posts: 4
don't understand what is happening, chart keeps freezing. timer remains the same value, I have to reconnect for it to update but it freezes again
[2025-02-12 16:06:57]
Sierra_Chart Engineering - Posts: 18836
Refer to help topic 3:
[2025-02-12 16:58:45]
I have went through almost all the points to no avail, could you give me further insight please? my chart is frozen, only when i reconnect then it will show the most current data, but will remain like that until I reconnect again.
What do you think I should do specifically? it was working yesterday fine
[2025-02-12 17:50:59]
John - SC Support - Posts: 38782
Close all of the Chartbooks with "File >> Close All Chartbooks".
Open a single chart for the symbol you have an issue with through "File >> Find Symbol". Tell us that symbol of the chart. Tell us about *one* symbol only.
After about 10 seconds after the data finishes loading for this chart, provide a copy of the Message Log following these instructions:
[2025-02-12 18:37:09]
2025-02-12 18:32:10.139 | Trade activity files set size: 531
2025-02-12 18:32:10.179 | Reading Internal Order ID file.
2025-02-12 18:32:10.181 | Reading Trade Orders file.
2025-02-12 18:32:10.181 | Reading Trade Positions file.
2025-02-12 18:32:10.181 | Reading Trade Account Data files.
2025-02-12 18:32:10.182 | Software version: 2725 64-bit
2025-02-12 18:32:10.182 | Primary Thread ID: 21004
2025-02-12 18:32:10.182 | Usage end date: 2025-03-09
2025-02-12 18:32:10.182 | Enabled for: Advanced Features 2.
2025-02-12 18:32:10.182 | Enabled for: Sierra Chart Historical Data Service.
2025-02-12 18:32:10.182 | Enabled for: Denali Real-Time Exchange Data Feed.
2025-02-12 18:32:10.182 | Enabled for: Delayed Denali Exchange Data Feed.
2025-02-12 18:32:10.182 | Enabled for exchange2: CME
2025-02-12 18:32:10.182 | Allow Support for Sierra Chart Data Feeds is enabled.
2025-02-12 18:32:10.182 | Current selected Data/Trading service: Teton CME Order Routing
2025-02-12 18:32:10.182 | Custom symbol settings values: disabled
2025-02-12 18:32:10.182 | Chart Update Interval: 500
2025-02-12 18:32:10.182 | Intraday Data Storage Time Unit: 0
2025-02-12 18:32:10.182 | Time Zone: +00:00:00 (UTC+00)
2025-02-12 18:32:10.182 | 2025-02-12 18:32:10 Local computer time in UTC
2025-02-12 18:32:10.182 | 2025-02-12 18:32:10 Local computer time in SC Time Zone
2025-02-12 18:32:10.182 | 2025-02-12 18:32:09 Server time in UTC
2025-02-12 18:32:10.182 | Local computer UTC time and Server UTC time difference: 0 seconds.
2025-02-12 18:32:10.182 | Program path: C:\SierraChart\
2025-02-12 18:32:10.182 | Data Files path: C:\SierraChart\Data\
2025-02-12 18:32:10.182 | OS Version Number: 10.0
2025-02-12 18:32:10.182 | Locale Setting: C
2025-02-12 18:32:10.182 | DLLs: Imbalances#002_64.dll, Imbalances#003_64.dll, imbalncespPOCchange_64.dll, UserContributedStudies_64.dll
2025-02-12 18:32:10.182 | Allowed protected custom studies:
2025-02-12 18:32:10.182 | Crash reporter started: true
2025-02-12 18:32:10.197 | Checking for new symbol settings. Requested symbol settings MD5 for service code sc_futures_direct.dtc.trading. Request ID: 1.
2025-02-12 18:32:10.219 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Shutdown started. Waiting for graceful close.
2025-02-12 18:32:10.319 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Socket gracefully closed by remote side.
2025-02-12 18:32:10.319 | HTTPS connection ID:1 to login.sierrachart.com:443 for request ID:1 (1) | Closed.
2025-02-12 18:32:10.504 | Received 5 login tokens.
2025-02-12 18:32:10.953 | Symbol settings MD5 received. Request ID: 1.
2025-02-12 18:32:10.953 | Symbol settings are up-to-date for sc_futures_direct.dtc.trading.
2025-02-12 18:32:12.694 | Requested user files to download.
2025-02-12 18:32:14.687 |
2025-02-12 18:32:14.687 | Teton CME Order Routing | Firm: Dorman/Stage5
2025-02-12 18:32:14.689 | Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11093
2025-02-12 18:32:14.690 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-12 18:32:14.690 | DTC Client socket (1) | New receive buffer size: 0
2025-02-12 18:32:14.690 | DTC Client socket (1) | Connecting to IP: 208.185.224.130.
2025-02-12 18:32:14.786 | Teton CME Order Routing | Network connection to server complete.
2025-02-12 18:32:14.786 | Teton CME Order Routing | Starting socket receive thread.
2025-02-12 18:32:14.786 | Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none
2025-02-12 18:32:15.101 | Teton CME Order Routing | Setting DTC encoding to Binary VLS
2025-02-12 18:32:15.101 | Teton CME Order Routing | Sending logon request message.
2025-02-12 18:32:15.194 | Teton CME Order Routing | Received logon response.
2025-02-12 18:32:15.194 | Teton CME Order Routing | Server Name: SC DTC Server. Build=52100.
2025-02-12 18:32:15.194 | Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8
2025-02-12 18:32:15.194 | Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading.
2025-02-12 18:32:15.194 | Teton CME Order Routing | Trading is supported.
2025-02-12 18:32:15.194 | Teton CME Order Routing | Order cancel and replace is supported.
2025-02-12 18:32:15.194 | Teton CME Order Routing | OCO Orders supported.
2025-02-12 18:32:15.194 | Teton CME Order Routing | Bracket Orders supported.
2025-02-12 18:32:15.194 | Teton CME Order Routing | MarketDepthIsSupported: 1
2025-02-12 18:32:15.194 | Teton CME Order Routing | Connected to server complete.
2025-02-12 18:32:15.194 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-02-12 18:32:15.194 | Teton CME Order Routing | Performing query for most recent Order Activity Date-Time.
2025-02-12 18:32:15.224 | Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2024-12-07 14:06:42.202196
2025-02-12 18:32:15.339 | Updated verified funded futures trading account ending date to: 2025-03-14 18:32:15
2025-02-12 18:32:16.756 | Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=1948A
2025-02-12 18:32:17.912 | Files to Open on Startup | Opening file: ExampleChartbook.cht
2025-02-12 18:32:17.926 | XAUUSD 5 Min #1 | Reloading chart.
2025-02-12 18:32:17.940 | XAUUSD 1 Min #2 | Reloading chart.
2025-02-12 18:32:17.948 | USOil 1 Min #4 | Reloading chart.
2025-02-12 18:32:17.955 | ESH25_FUT_CME 1 Min #5 | Reloading chart.
2025-02-12 18:32:17.963 | SPX500 Daily #6 | Reloading chart.
2025-02-12 18:32:17.972 | EURUSD Daily #7 | Reloading chart.
2025-02-12 18:32:17.981 | EURUSD 5 Min #8 | Reloading chart.
2025-02-12 18:32:17.991 | ESH25_FUT_CME #9 | Reloading chart.
2025-02-12 18:32:18.010 | US30 120 Min #3 | Reloading chart.
2025-02-12 18:32:18.196 | ESH25_FUT_CME 1 Min #10 | Reloading chart.
2025-02-12 18:32:18.206 | AAPL-NQTV 5 Min #11 | Reloading chart.
2025-02-12 18:32:18.263 | SPX500 Daily #6 | Chart data loading complete.
2025-02-12 18:32:18.265 | EURUSD Daily #7 | Chart data loading complete.
2025-02-12 18:32:18.268 | USOil 1 Min #4 | Chart data loading complete.
2025-02-12 18:32:18.360 | AAPL-NQTV 5 Min #11 | Out of order timestamps detected. Chart tool drawings and some chart studies may not function properly. Prior Date Time: 2025-01-29 15:55:00. Next Bar Date Time: 2025-01-29 13:55:00. Filename: AAPL-NQTV.scid
2025-02-12 18:32:18.426 | Using Bid/Ask average for last trade price for XAUUSD
2025-02-12 18:32:18.426 | Using symbol data fast lookup vector
2025-02-12 18:32:18.426 | SC Data with Depth | Starting real-time market data updates for: XAUUSD. ID: 1 Service code: fxcm
2025-02-12 18:32:18.428 | SC Data with Depth | Connecting to the server ds12.sierracharts.com. Port 443
2025-02-12 18:32:18.428 | SC Data with Depth | Requesting security definition data for: XAUUSD. ID: 1
2025-02-12 18:32:18.428 | Starting DelayedDownloadMonitoringTimer
2025-02-12 18:32:18.428 | Starting HDTimeoutTimer
2025-02-12 18:32:18.428 | Added historical Intraday data request for XAUUSD to the queue.
2025-02-12 18:32:18.428 | Intraday data recording state for symbol XAUUSD is set to download 'Pending'.
2025-02-12 18:32:18.429 | DTC Client socket (2) | Creating socket.
2025-02-12 18:32:18.429 | DTC Client socket (2) | New receive buffer size: 0
2025-02-12 18:32:18.429 | DTC Client socket (2) | Connecting to IP: 69.39.70.241.
2025-02-12 18:32:18.430 | Triggering next historical data download in queue.
2025-02-12 18:32:18.432 | Delaying start of download for XAUUSD.
2025-02-12 18:32:18.455 | Using Bid/Ask average for last trade price for SPX500
2025-02-12 18:32:18.456 | SC Data with Depth | Starting real-time market data updates for: SPX500. ID: 2 Service code: fxcm
2025-02-12 18:32:18.456 | SC Data with Depth | Requesting security definition data for: SPX500. ID: 2
2025-02-12 18:32:18.456 | Mapping ESH25_FUT_CME to ESH25. Service code: cme
2025-02-12 18:32:18.457 | Denali Data Feed | Starting real-time market data updates for: ESH25_FUT_CME (ESH25). ID: 3 Service code: cme
2025-02-12 18:32:18.458 | Denali Data Feed | Connecting to the server ds32.sierracharts.com. Port 10048
2025-02-12 18:32:18.458 | Denali Data Feed | Requesting security definition data for: ESH25_FUT_CME (ESH25). ID: 3
2025-02-12 18:32:18.458 | Added historical Intraday data request for ESH25_FUT_CME to the queue.
2025-02-12 18:32:18.458 | Intraday data recording state for symbol ESH25_FUT_CME is set to download 'Pending'.
2025-02-12 18:32:18.458 | Triggering next historical data download in queue.
2025-02-12 18:32:18.459 | Using Bid/Ask average for last trade price for USOil
2025-02-12 18:32:18.459 | SC Data with Depth | Starting real-time market data updates for: USOil. ID: 4 Service code: fxcm
2025-02-12 18:32:18.459 | SC Data with Depth | Requesting security definition data for: USOil. ID: 4
2025-02-12 18:32:18.459 | Added historical Intraday data request for USOil to the queue.
2025-02-12 18:32:18.459 | Intraday data recording state for symbol USOil is set to download 'Pending'.
2025-02-12 18:32:18.459 | Triggering next historical data download in queue.
2025-02-12 18:32:18.468 | DTC Client socket (3) | Creating socket.
2025-02-12 18:32:18.468 | DTC Client socket (3) | New receive buffer size: 0
2025-02-12 18:32:18.468 | DTC Client socket (3) | Connecting to IP: 67.214.125.3.
2025-02-12 18:32:18.487 | Using Bid/Ask average for last trade price for EURUSD
2025-02-12 18:32:18.487 | SC Data with Depth | Starting real-time market data updates for: EURUSD. ID: 5 Service code: fxcm
2025-02-12 18:32:18.487 | SC Data with Depth | Requesting security definition data for: EURUSD. ID: 5
2025-02-12 18:32:18.487 | Added historical Intraday data request for EURUSD to the queue.
2025-02-12 18:32:18.487 | Intraday data recording state for symbol EURUSD is set to download 'Pending'.
2025-02-12 18:32:18.487 | Triggering next historical data download in queue.
2025-02-12 18:32:18.502 | AAPL-NQTV 5 Min #11 | Chart data loading complete.
2025-02-12 18:32:18.518 | Using Bid/Ask average for last trade price for US30
2025-02-12 18:32:18.518 | SC Data with Depth | Starting real-time market data updates for: US30. ID: 6 Service code: fxcm
2025-02-12 18:32:18.518 | SC Data with Depth | Requesting security definition data for: US30. ID: 6
2025-02-12 18:32:18.518 | Added historical Intraday data request for US30 to the queue.
2025-02-12 18:32:18.518 | Intraday data recording state for symbol US30 is set to download 'Pending'.
2025-02-12 18:32:18.518 | Triggering next historical data download in queue.
2025-02-12 18:32:18.528 | SC Data with Depth | Network connection to server complete.
2025-02-12 18:32:18.528 | SC Data with Depth | Starting socket receive thread.
2025-02-12 18:32:18.528 | SC Data with Depth | Sending encoding request to server: Binary VLS. Compression: standard
2025-02-12 18:32:18.551 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH25_FUT_CME
2025-02-12 18:32:18.551 | Teton CME Order Routing | Setting external service identifier for symbol ESH25_FUT_CME to 5002
2025-02-12 18:32:18.551 | Teton CME Order Routing | Received security definition for symbol ESH25_FUT_CME
2025-02-12 18:32:18.574 | Denali Data Feed | Network connection to server complete.
2025-02-12 18:32:18.574 | Denali Data Feed | Starting socket receive thread.
2025-02-12 18:32:18.574 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-02-12 18:32:18.637 | SC Data with Depth | Setting DTC encoding to Binary VLS
2025-02-12 18:32:18.637 | SC Data with Depth | Sending logon request message.
2025-02-12 18:32:18.676 | EURUSD[M] 5 Min #8 | Chart data loading complete.
2025-02-12 18:32:18.700 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-02-12 18:32:18.700 | Denali Data Feed | Sending logon request message.
2025-02-12 18:32:18.704 | Mapping AAPL-NQTV to AAPL-NQTV. Service code: nasdaq_exchange.data
2025-02-12 18:32:18.704 | Delayed Data Feed | Starting real-time market data updates for: AAPL-NQTV (AAPL-NQTV). ID: 7 Service code: nasdaq_exchange.data
2025-02-12 18:32:18.705 | Delayed Data Feed | Connecting to the server ds33.sierracharts.com. Port 10043
2025-02-12 18:32:18.705 | Delayed Data Feed | Requesting security definition data for: AAPL-NQTV (AAPL-NQTV). ID: 7
2025-02-12 18:32:18.705 | Added historical Intraday data request for AAPL-NQTV to the queue.
2025-02-12 18:32:18.705 | Intraday data recording state for symbol AAPL-NQTV is set to download 'Pending'.
2025-02-12 18:32:18.705 | Triggering next historical data download in queue.
2025-02-12 18:32:18.722 | DTC Client socket (4) | Creating socket.
2025-02-12 18:32:18.722 | DTC Client socket (4) | New receive buffer size: 0
2025-02-12 18:32:18.722 | DTC Client socket (4) | Connecting to IP: 69.39.70.245.
2025-02-12 18:32:18.821 | Delayed Data Feed | Network connection to server complete.
2025-02-12 18:32:18.821 | Delayed Data Feed | Starting socket receive thread.
2025-02-12 18:32:18.821 | Delayed Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-02-12 18:32:18.826 | SC Data with Depth | Received logon response.
2025-02-12 18:32:18.826 | SC Data with Depth | Server Name: SC Realtime Server.
2025-02-12 18:32:18.826 | SC Data with Depth | Server protocol version: 8. Client protocol version: 8
2025-02-12 18:32:18.826 | SC Data with Depth | Successfully connected.
2025-02-12 18:32:18.826 | SC Data with Depth | Trading is not supported.
2025-02-12 18:32:18.826 | SC Data with Depth | MarketDepthIsSupported: 1
2025-02-12 18:32:18.826 | SC Data with Depth | Restarting real-time data updates for symbol: EURUSD
2025-02-12 18:32:18.826 | SC Data with Depth | Restarting real-time data updates for symbol: SPX500
2025-02-12 18:32:18.826 | SC Data with Depth | Restarting real-time data updates for symbol: US30
2025-02-12 18:32:18.826 | SC Data with Depth | Restarting real-time data updates for symbol: USOil
2025-02-12 18:32:18.826 | SC Data with Depth | Restarting real-time data updates for symbol: XAUUSD
2025-02-12 18:32:18.933 | Delayed Data Feed | Setting DTC encoding to Binary VLS
2025-02-12 18:32:18.933 | Delayed Data Feed | Sending logon request message.
2025-02-12 18:32:19.024 | SC Data with Depth | Setting external service identifier for symbol EURUSD to 18
2025-02-12 18:32:19.024 | SC Data with Depth | Received security definition for symbol EURUSD
2025-02-12 18:32:19.024 | SC Data with Depth | Setting external service identifier for symbol SPX500 to 55
2025-02-12 18:32:19.024 | SC Data with Depth | Received security definition for symbol SPX500
2025-02-12 18:32:19.024 | SC Data with Depth | Setting external service identifier for symbol US30 to 58
2025-02-12 18:32:19.024 | SC Data with Depth | Received security definition for symbol US30
2025-02-12 18:32:19.024 | SC Data with Depth | Setting external service identifier for symbol USOil to 60
2025-02-12 18:32:19.024 | SC Data with Depth | Received security definition for symbol USOil
2025-02-12 18:32:19.024 | SC Data with Depth | Setting external service identifier for symbol XAUUSD to 62
2025-02-12 18:32:19.024 | SC Data with Depth | Received security definition for symbol XAUUSD
2025-02-12 18:32:19.124 | Delayed Data Feed | Received logon response.
2025-02-12 18:32:19.124 | Delayed Data Feed | Server Name: SC Realtime Server.
2025-02-12 18:32:19.124 | Delayed Data Feed | Server protocol version: 8. Client protocol version: 8
2025-02-12 18:32:19.124 | Delayed Data Feed | Successfully connected.
2025-02-12 18:32:19.124 | Delayed Data Feed | Trading is not supported.
2025-02-12 18:32:19.124 | Delayed Data Feed | MarketDepthIsSupported: 1
2025-02-12 18:32:19.124 | Delayed Data Feed | Restarting real-time data updates for symbol: AAPL-NQTV -> AAPL-NQTV
2025-02-12 18:32:19.170 | Denali Data Feed | Received logon response.
2025-02-12 18:32:19.170 | Denali Data Feed | Server Name: RealTimeServer.
2025-02-12 18:32:19.170 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-02-12 18:32:19.170 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-02-12 18:32:19.170 | Denali Data Feed | Failed connections: 1
2025-02-12 18:32:19.170 | Denali Data Feed | Waiting for socket receive thread to end
2025-02-12 18:32:19.171 | DTC Client socket (3) | CloseSocket call.
2025-02-12 18:32:19.171 | Denali Data Feed | Disconnected from the server.
2025-02-12 18:32:19.171 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-02-12 18:32:19.171 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-02-12 18:32:19.268 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-02-12 18:32:19.268 | DTC Client socket (3) | Closed.
2025-02-12 18:32:19.310 | Delayed Data Feed | Setting external service identifier for symbol AAPL-NQTV to 24
2025-02-12 18:32:19.310 | Delayed Data Feed | Received security definition for symbol AAPL-NQTV
2025-02-12 18:32:19.331 | US30[M] 120 Min #3 | Chart data loading complete.
2025-02-12 18:32:19.520 | ESH25_FUT_CME[M] 1 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-12 18:32:19.520 | ESH25_FUT_CME[M] 1 Min #10 | Chart data loading complete.
2025-02-12 18:32:19.830 | XAUUSD[M] 1 Min #2 | Chart data loading complete.
2025-02-12 18:32:20.006 | ESH25_FUT_CME[M] #9 | Chart data loading complete.
2025-02-12 18:32:20.353 | ESH25_FUT_CME[M] 1 Min #5 | Chart data loading complete.
2025-02-12 18:32:20.739 | XAUUSD[M] 5 Min #1 | Chart data loading complete.
2025-02-12 18:32:24.426 | HD Request # 1 | Downloading Intraday chart data for XAUUSD to the file XAUUSD.scid. Service: fxcm
2025-02-12 18:32:24.427 | HD Request # 1 | Download start date-time: 2025-02-12 18:31:37.000000. File last date-time: 2025-02-12 18:31:37.980000
2025-02-12 18:32:24.427 | HD Request # 1 | Using server: ds12.sierracharts.com port 10149
2025-02-12 18:32:24.427 | Socket (3) | Creating socket.
2025-02-12 18:32:24.427 | Socket (3) | New receive buffer size: 0
2025-02-12 18:32:24.427 | Socket (3) | Connecting to IP: 69.39.70.241.
2025-02-12 18:32:24.663 | HD Request # 1 | Setting DTC encoding to Binary VLS
2025-02-12 18:32:24.663 | HD Request # 1 | Sending historical data logon request message.
2025-02-12 18:32:24.795 | HD Request # 1 | Requesting Intraday data. Start date-time: 2025-02-12 18:31:37. Record interval: 0. Symbol: XAUUSD
2025-02-12 18:32:24.923 | HD Request # 1 | Decompressing data.
2025-02-12 18:32:25.021 | HD Request # 1 | Receiving Intraday data for XAUUSD starting at 2025-02-12 18:31:37.018000
2025-02-12 18:32:25.022 | Socket (3) | CloseSocket call.
2025-02-12 18:32:25.022 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-02-12 18:32:25.023 | Historical data download thread signaled to stop.
2025-02-12 18:32:25.023 | HD Request # 1 | Timestamp of first Intraday data file record written: 2025-02-12 18:31:39.728000.
2025-02-12 18:32:25.023 | HD Request # 1 | Received 333 Intraday data records from 2025-02-12 18:31:37.018000 to 2025-02-12 18:32:24.803000 (47.8 seconds. Delay: 0.2 seconds) and wrote 311 records for XAUUSD
2025-02-12 18:32:25.031 | HD Request # 1 | Add time&sales data | Remembered last file record date-time: 2025-02-12 18:32:24.803000
2025-02-12 18:32:25.031 | Added 2 Time and Sales records to Intraday data file for XAUUSD after download.
2025-02-12 18:32:25.032 | HD Request # 1 | Completion time: 1s.
2025-02-12 18:32:25.032 | HD Request # 1 | Intraday data download complete for XAUUSD. Unique request ID: 1
2025-02-12 18:32:25.032 | Removing historical data download ID 1.
2025-02-12 18:32:25.032 | Real-time Intraday chart data file updates started for XAUUSD
2025-02-12 18:32:25.032 | Intraday chart data file opened for XAUUSD
2025-02-12 18:32:25.032 | HD Request # 1 | Enabling Intraday chart updating for symbol.
2025-02-12 18:32:25.032 | Triggering next historical data download in queue.
2025-02-12 18:32:25.033 | Delaying start of download for ESH25_FUT_CME.
2025-02-12 18:32:25.126 | Socket (3) | Socket gracefully closed by remote side.
2025-02-12 18:32:25.126 | Socket (3) | Closed.
2025-02-12 18:32:30.358 | Opened cached Intraday file: C:\SierraChart\Data\XAUUSD.scid. Thread ID: 4968
2025-02-12 18:32:35.337 | ExtendTheFundedTradingAccountStatusExpirationDate: Sending request.
2025-02-12 18:32:35.813 | ExtendTheFundedTradingAccountStatusExpirationDate | Result: {"Result":"The Funded Trading Account Status Expiration Date is more than 25 days into the future. The Date is currently: 2025-03-14"}. Success=true
2025-02-12 18:32:49.434 | HD Request # 2 | Downloading Intraday chart data for ESH25_FUT_CME to the file ESH25_FUT_CME.scid. Service: cme
2025-02-12 18:32:49.434 | HD Request # 2 | Download start date-time: 2025-02-12 18:30:48.000000. File last date-time: 2025-02-12 18:30:48.265000
2025-02-12 18:32:49.435 | HD Request # 2 | Using server: ds28.sierracharts.com port 10150
2025-02-12 18:32:49.435 | Socket (3) | Creating socket.
2025-02-12 18:32:49.435 | Socket (3) | New receive buffer size: 0
2025-02-12 18:32:49.435 | Socket (3) | Connecting to IP: 67.214.125.5.
2025-02-12 18:32:49.675 | HD Request # 2 | Setting DTC encoding to Binary VLS
2025-02-12 18:32:49.675 | HD Request # 2 | Sending historical data logon request message.
2025-02-12 18:32:49.818 | HD Request # 2 | Requesting Intraday data. Start date-time: 2025-02-12 18:30:48. Record interval: 0. Symbol: ESH25
2025-02-12 18:32:49.927 | HD Request # 2 | Decompressing data.
2025-02-12 18:32:50.129 | HD Request # 2 | Receiving Intraday data for ESH25_FUT_CME starting at 2025-02-12 18:30:48.123000
2025-02-12 18:32:50.131 | Socket (3) | CloseSocket call.
2025-02-12 18:32:50.131 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-02-12 18:32:50.132 | Historical data download thread signaled to stop.
2025-02-12 18:32:50.132 | HD Request # 2 | Timestamp of first Intraday data file record written: 2025-02-12 18:30:48.674000.
2025-02-12 18:32:50.132 | HD Request # 2 | Received 3216 Intraday data records from 2025-02-12 18:30:48.123000 to 2025-02-12 18:32:48.585000 (2.0 minutes. Delay: 1.5 seconds) and wrote 3212 records for ESH25_FUT_CME
2025-02-12 18:32:50.139 | HD Request # 2 | Add time&sales data | Remembered last file record date-time: 2025-02-12 18:32:48.585000
2025-02-12 18:32:50.139 | HD Request # 2 | Completion time: 1s.
2025-02-12 18:32:50.139 | HD Request # 2 | Intraday data download complete for ESH25_FUT_CME. Unique request ID: 2
2025-02-12 18:32:50.139 | Removing historical data download ID 2.
2025-02-12 18:32:50.139 | Real-time Intraday chart data file updates started for ESH25_FUT_CME
2025-02-12 18:32:50.139 | Intraday chart data file opened for ESH25_FUT_CME
2025-02-12 18:32:50.139 | HD Request # 2 | Enabling Intraday chart updating for symbol.
2025-02-12 18:32:50.139 | Triggering next historical data download in queue.
2025-02-12 18:32:50.139 | Historical data for ESH25_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-02-12 18:32:50.139 | HD Request # 3 | Downloading Intraday chart data for USOil to the file USOil.scid. Service: fxcm
2025-02-12 18:32:50.140 | HD Request # 3 | Download start date-time: 2025-02-12 18:31:32.000000. File last date-time: 2025-02-12 18:31:32.709000
2025-02-12 18:32:50.140 | HD Request # 3 | Using server: ds4.sierracharts.com port 10149
2025-02-12 18:32:50.143 | Socket (5) | Creating socket.
2025-02-12 18:32:50.143 | Socket (5) | New receive buffer size: 0
2025-02-12 18:32:50.143 | Socket (5) | Connecting to IP: 64.152.155.113.
2025-02-12 18:32:50.233 | Socket (3) | Socket gracefully closed by remote side.
2025-02-12 18:32:50.233 | Socket (3) | Closed.
2025-02-12 18:32:50.356 | HD Request # 3 | Setting DTC encoding to Binary VLS
2025-02-12 18:32:50.356 | HD Request # 3 | Sending historical data logon request message.
2025-02-12 18:32:50.479 | HD Request # 3 | Requesting Intraday data. Start date-time: 2025-02-12 18:31:32. Record interval: 0. Symbol: USOil
2025-02-12 18:32:50.576 | HD Request # 3 | Decompressing data.
2025-02-12 18:32:50.669 | HD Request # 3 | Receiving Intraday data for USOil starting at 2025-02-12 18:31:32.709000
2025-02-12 18:32:50.669 | Socket (5) | CloseSocket call.
2025-02-12 18:32:50.669 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-02-12 18:32:50.670 | Historical data download thread signaled to stop.
2025-02-12 18:32:50.671 | HD Request # 3 | Timestamp of first Intraday data file record written: 2025-02-12 18:31:42.745000.
2025-02-12 18:32:50.671 | HD Request # 3 | Received 51 Intraday data records from 2025-02-12 18:31:32.709000 to 2025-02-12 18:32:47.964000 (75.3 seconds. Delay: 2.7 seconds) and wrote 50 records for USOil
2025-02-12 18:32:50.677 | HD Request # 3 | Add time&sales data | Remembered last file record date-time: 2025-02-12 18:32:47.964000
2025-02-12 18:32:50.677 | HD Request # 3 | Completion time: 0s.
2025-02-12 18:32:50.677 | HD Request # 3 | Intraday data download complete for USOil. Unique request ID: 3
2025-02-12 18:32:50.677 | Removing historical data download ID 3.
2025-02-12 18:32:50.677 | Real-time Intraday chart data file updates started for USOil
2025-02-12 18:32:50.677 | Intraday chart data file opened for USOil
2025-02-12 18:32:50.677 | HD Request # 3 | Enabling Intraday chart updating for symbol.
2025-02-12 18:32:50.677 | Triggering next historical data download in queue.
2025-02-12 18:32:50.677 | HD Request # 4 | Downloading Intraday chart data for EURUSD to the file EURUSD.scid. Service: fxcm
2025-02-12 18:32:50.678 | HD Request # 4 | Download start date-time: 2025-02-12 18:31:37.000000. File last date-time: 2025-02-12 18:31:37.712000
2025-02-12 18:32:50.678 | HD Request # 4 | Using server: ds12.sierracharts.com port 10150
2025-02-12 18:32:50.678 | Socket (3) | Creating socket.
2025-02-12 18:32:50.678 | Socket (3) | New receive buffer size: 0
2025-02-12 18:32:50.678 | Socket (3) | Connecting to IP: 69.39.70.241.
2025-02-12 18:32:50.764 | Socket (5) | Socket gracefully closed by remote side.
2025-02-12 18:32:50.764 | Socket (5) | Closed.
2025-02-12 18:32:50.878 | HD Request # 4 | Setting DTC encoding to Binary VLS
2025-02-12 18:32:50.878 | HD Request # 4 | Sending historical data logon request message.
2025-02-12 18:32:51.004 | HD Request # 4 | Requesting Intraday data. Start date-time: 2025-02-12 18:31:37. Record interval: 0. Symbol: EURUSD
2025-02-12 18:32:51.100 | HD Request # 4 | Decompressing data.
2025-02-12 18:32:51.290 | HD Request # 4 | Receiving Intraday data for EURUSD starting at 2025-02-12 18:31:37.013000
2025-02-12 18:32:51.291 | Socket (3) | CloseSocket call.
2025-02-12 18:32:51.291 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-02-12 18:32:51.291 | Historical data download thread signaled to stop.
2025-02-12 18:32:51.291 | HD Request # 4 | Timestamp of first Intraday data file record written: 2025-02-12 18:31:38.099000.
2025-02-12 18:32:51.291 | HD Request # 4 | Received 793 Intraday data records from 2025-02-12 18:31:37.013000 to 2025-02-12 18:32:50.793000 (73.8 seconds. Delay: 0.5 seconds) and wrote 783 records for EURUSD
2025-02-12 18:32:51.299 | HD Request # 4 | Add time&sales data | Remembered last file record date-time: 2025-02-12 18:32:50.793000
2025-02-12 18:32:51.299 | Added 4 Time and Sales records to Intraday data file for EURUSD after download.
2025-02-12 18:32:51.300 | HD Request # 4 | Completion time: 1s.
2025-02-12 18:32:51.300 | HD Request # 4 | Intraday data download complete for EURUSD. Unique request ID: 4
2025-02-12 18:32:51.300 | Removing historical data download ID 4.
2025-02-12 18:32:51.300 | Real-time Intraday chart data file updates started for EURUSD
2025-02-12 18:32:51.300 | Intraday chart data file opened for EURUSD
2025-02-12 18:32:51.300 | HD Request # 4 | Enabling Intraday chart updating for symbol.
2025-02-12 18:32:51.300 | Triggering next historical data download in queue.
2025-02-12 18:32:51.300 | HD Request # 5 | Downloading Intraday chart data for US30 to the file US30.scid. Service: fxcm
2025-02-12 18:32:51.301 | HD Request # 5 | Download start date-time: 2025-02-12 18:31:37.000000. File last date-time: 2025-02-12 18:31:37.771000
2025-02-12 18:32:51.301 | HD Request # 5 | Using server: ds4.sierracharts.com port 10149
2025-02-12 18:32:51.301 | Socket (5) | Creating socket.
2025-02-12 18:32:51.301 | Socket (5) | New receive buffer size: 0
2025-02-12 18:32:51.301 | Socket (5) | Connecting to IP: 64.152.155.113.
2025-02-12 18:32:51.390 | Socket (3) | Socket gracefully closed by remote side.
2025-02-12 18:32:51.390 | Socket (3) | Closed.
2025-02-12 18:32:51.496 | HD Request # 5 | Setting DTC encoding to Binary VLS
2025-02-12 18:32:51.496 | HD Request # 5 | Sending historical data logon request message.
2025-02-12 18:32:51.588 | HD Request # 5 | Requesting Intraday data. Start date-time: 2025-02-12 18:31:37. Record interval: 0. Symbol: US30
2025-02-12 18:32:51.685 | HD Request # 5 | Decompressing data.
2025-02-12 18:32:51.789 | HD Request # 5 | Receiving Intraday data for US30 starting at 2025-02-12 18:31:37.280000
2025-02-12 18:32:51.789 | Socket (5) | CloseSocket call.
2025-02-12 18:32:51.789 | Socket (5) | Shutdown started. Waiting for graceful close.
2025-02-12 18:32:51.790 | Historical data download thread signaled to stop.
2025-02-12 18:32:51.791 | HD Request # 5 | Timestamp of first Intraday data file record written: 2025-02-12 18:31:38.177000.
2025-02-12 18:32:51.791 | HD Request # 5 | Received 413 Intraday data records from 2025-02-12 18:31:37.280000 to 2025-02-12 18:32:50.932000 (73.7 seconds. Delay: 0.9 seconds) and wrote 402 records for US30
2025-02-12 18:32:51.797 | HD Request # 5 | Add time&sales data | Remembered last file record date-time: 2025-02-12 18:32:50.932000
2025-02-12 18:32:51.797 | HD Request # 5 | Completion time: 0s.
2025-02-12 18:32:51.797 | HD Request # 5 | Intraday data download complete for US30. Unique request ID: 5
2025-02-12 18:32:51.797 | Removing historical data download ID 5.
2025-02-12 18:32:51.797 | Real-time Intraday chart data file updates started for US30
2025-02-12 18:32:51.797 | Intraday chart data file opened for US30
2025-02-12 18:32:51.797 | HD Request # 5 | Enabling Intraday chart updating for symbol.
2025-02-12 18:32:51.797 | Triggering next historical data download in queue.
2025-02-12 18:32:51.797 | HD Request # 6 | Downloading Intraday chart data for AAPL-NQTV to the file AAPL-NQTV.scid. Service: nasdaq_exchange.data
2025-02-12 18:32:51.798 | HD Request # 6 | Download start date-time: 2025-02-12 18:16:37.000000. File last date-time: 2025-02-12 18:16:37.880000
2025-02-12 18:32:51.798 | HD Request # 6 | Using server: ds33.sierracharts.com port 10150
2025-02-12 18:32:51.798 | Socket (3) | Creating socket.
2025-02-12 18:32:51.798 | Socket (3) | New receive buffer size: 0
2025-02-12 18:32:51.798 | Socket (3) | Connecting to IP: 69.39.70.245.
2025-02-12 18:32:51.893 | Socket (5) | Socket gracefully closed by remote side.
2025-02-12 18:32:51.894 | Socket (5) | Closed.
2025-02-12 18:32:52.007 | HD Request # 6 | Setting DTC encoding to Binary VLS
2025-02-12 18:32:52.007 | HD Request # 6 | Sending historical data logon request message.
2025-02-12 18:32:52.148 | HD Request # 6 | Requesting Intraday data. Start date-time: 2025-02-12 18:16:37. Record interval: 0. Symbol: AAPL-NQTV
2025-02-12 18:32:52.246 | HD Request # 6 | Decompressing data.
2025-02-12 18:32:52.347 | HD Request # 6 | Receiving Intraday data for AAPL-NQTV starting at 2025-02-12 18:16:37.880000
2025-02-12 18:32:52.347 | Socket (3) | CloseSocket call.
2025-02-12 18:32:52.347 | Socket (3) | Shutdown started. Waiting for graceful close.
2025-02-12 18:32:52.348 | Historical data download thread signaled to stop.
2025-02-12 18:32:52.348 | HD Request # 6 | Timestamp of first Intraday data file record written: 2025-02-12 18:16:39.887000.
2025-02-12 18:32:52.348 | HD Request # 6 | Received 182 Intraday data records from 2025-02-12 18:16:37.880000 to 2025-02-12 18:17:51.515007 (73.6 seconds. Delay: 15.0 minutes) and wrote 181 records for AAPL-NQTV
2025-02-12 18:32:52.354 | HD Request # 6 | Add time&sales data | Remembered last file record date-time: 2025-02-12 18:17:51.515007
2025-02-12 18:32:52.354 | Added 1 Time and Sales records to Intraday data file for AAPL-NQTV after download.
2025-02-12 18:32:52.356 | HD Request # 6 | Completion time: 1s.
2025-02-12 18:32:52.356 | HD Request # 6 | Intraday data download complete for AAPL-NQTV. Unique request ID: 6
2025-02-12 18:32:52.356 | Removing historical data download ID 6.
2025-02-12 18:32:52.356 | Real-time Intraday chart data file updates started for AAPL-NQTV
2025-02-12 18:32:52.356 | Intraday chart data file opened for AAPL-NQTV
2025-02-12 18:32:52.356 | HD Request # 6 | Enabling Intraday chart updating for symbol.
2025-02-12 18:32:52.356 | No download requests in the queue to start downloads for.
2025-02-12 18:32:52.446 | Socket (3) | Socket gracefully closed by remote side.
2025-02-12 18:32:52.447 | Socket (3) | Closed.
2025-02-12 18:32:53.279 | Opened cached Intraday file: C:\SierraChart\Data\AAPL-NQTV.scid. Thread ID: 24948
2025-02-12 18:32:55.581 | Opened cached Intraday file: C:\SierraChart\Data\USOil.scid. Thread ID: 4968
2025-02-12 18:32:55.581 | Opened cached Intraday file: C:\SierraChart\Data\EURUSD.scid. Thread ID: 4968
2025-02-12 18:32:55.581 | Opened cached Intraday file: C:\SierraChart\Data\US30.scid. Thread ID: 4968
2025-02-12 18:33:10.764 | ESH25_FUT_CME 15 Min #2 | Reloading chart.
2025-02-12 18:33:10.777 | ESH25_FUT_CME 5 Min #10 | Reloading chart.
2025-02-12 18:33:10.805 | ESH25_FUT_CME 30 Min #6 | Reloading chart.
2025-02-12 18:33:10.814 | ESH25_FUT_CME 60 Min #7 | Reloading chart.
2025-02-12 18:33:10.822 | ESH25_FUT_CME #12 | Reloading chart.
2025-02-12 18:33:11.198 | ESH25_FUT_CME #12 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-12 18:33:11.198 | ESH25_FUT_CME #12 | Chart data loading complete.
2025-02-12 18:33:15.195 | Requesting market depth updates for: ESH25_FUT_CME if supported. NumLevels=100
2025-02-12 18:33:17.962 | ESH25_FUT_CME[M] 15 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-12 18:33:18.007 | ESH25_FUT_CME[M] 15 Min #2 | Chart data loading complete.
2025-02-12 18:33:18.261 | ESH25_FUT_CME[M] 30 Min #6 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-12 18:33:18.272 | ESH25_FUT_CME[M] 30 Min #6 | Chart data loading complete.
2025-02-12 18:33:18.289 | ESH25_FUT_CME[M] 15 Min #2 | Reloading chart.
2025-02-12 18:33:18.296 | ESH25_FUT_CME[M] 60 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-12 18:33:18.301 | ESH25_FUT_CME[M] 60 Min #7 | Chart data loading complete.
2025-02-12 18:33:18.353 | ESH25_FUT_CME[M] 30 Min #6 | Reloading chart.
2025-02-12 18:33:18.358 | ESH25_FUT_CME[M] 60 Min #7 | Reloading chart.
2025-02-12 18:33:19.169 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048
2025-02-12 18:33:19.192 | DTC Client socket (3) | Creating socket.
2025-02-12 18:33:19.192 | DTC Client socket (3) | New receive buffer size: 0
2025-02-12 18:33:19.192 | DTC Client socket (3) | Connecting to IP: 67.214.125.6.
2025-02-12 18:33:19.295 | Denali Data Feed | Network connection to server complete.
2025-02-12 18:33:19.295 | Denali Data Feed | Starting socket receive thread.
2025-02-12 18:33:19.295 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-02-12 18:33:19.418 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-02-12 18:33:19.418 | Denali Data Feed | Sending logon request message.
2025-02-12 18:33:19.901 | Denali Data Feed | Received logon response.
2025-02-12 18:33:19.901 | Denali Data Feed | Server Name: RealTimeServer.
2025-02-12 18:33:19.901 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-02-12 18:33:19.901 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-02-12 18:33:19.901 | Denali Data Feed | Failed connections: 2
2025-02-12 18:33:19.901 | Denali Data Feed | Waiting for socket receive thread to end
2025-02-12 18:33:19.901 | DTC Client socket (3) | CloseSocket call.
2025-02-12 18:33:19.901 | Denali Data Feed | Disconnected from the server.
2025-02-12 18:33:19.901 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-02-12 18:33:19.901 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-02-12 18:33:20.000 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-02-12 18:33:20.000 | DTC Client socket (3) | Closed.
2025-02-12 18:33:24.825 | ESH25_FUT_CME[M] 5 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-12 18:33:25.023 | ESH25_FUT_CME[M] 5 Min #10 | Chart data loading complete.
2025-02-12 18:33:25.235 | ESH25_FUT_CME[M] 15 Min #2 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-12 18:33:25.264 | ESH25_FUT_CME[M] 15 Min #2 | Chart data loading complete.
2025-02-12 18:33:25.309 | ESH25_FUT_CME[M] 5 Min #10 | Reloading chart.
2025-02-12 18:33:25.497 | ESH25_FUT_CME[M] 30 Min #6 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-12 18:33:25.504 | ESH25_FUT_CME[M] 30 Min #6 | Chart data loading complete.
2025-02-12 18:33:25.528 | ESH25_FUT_CME[M] 60 Min #7 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-12 18:33:25.532 | ESH25_FUT_CME[M] 60 Min #7 | Chart data loading complete.
2025-02-12 18:33:37.449 | ESH25_FUT_CME[M] 5 Min #10 | StartDateTimeForLoadingOrderFills: 00:00:00
2025-02-12 18:33:37.634 | ESH25_FUT_CME[M] 5 Min #10 | Chart data loading complete.
2025-02-12 18:34:18.556 | Saved Chartbook: ExampleChartbook.cht. Time: 0.0022 seconds.
2025-02-12 18:34:18.560 | Saved Chartbook: Orderflow.Cht. Time: 0.0028 seconds.
2025-02-12 18:34:19.897 | Denali Data Feed | Connecting to the server ds28-2.sierracharts.com. Port 10048
2025-02-12 18:34:19.897 | DTC Client socket (3) | Creating socket.
2025-02-12 18:34:19.897 | DTC Client socket (3) | New receive buffer size: 0
2025-02-12 18:34:19.897 | DTC Client socket (3) | Connecting to IP: 67.214.125.6.
2025-02-12 18:34:19.999 | Denali Data Feed | Network connection to server complete.
2025-02-12 18:34:19.999 | Denali Data Feed | Starting socket receive thread.
2025-02-12 18:34:19.999 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-02-12 18:34:20.117 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-02-12 18:34:20.117 | Denali Data Feed | Sending logon request message.
2025-02-12 18:34:20.194 | Unsubscribed from market depth data for ESH25_FUT_CME
2025-02-12 18:34:20.584 | Denali Data Feed | Received logon response.
2025-02-12 18:34:20.584 | Denali Data Feed | Server Name: RealTimeServer.
2025-02-12 18:34:20.584 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-02-12 18:34:20.584 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-02-12 18:34:20.584 | Denali Data Feed | Failed connections: 3
2025-02-12 18:34:20.584 | Denali Data Feed | Waiting for socket receive thread to end
2025-02-12 18:34:20.584 | DTC Client socket (3) | CloseSocket call.
2025-02-12 18:34:20.584 | Denali Data Feed | Disconnected from the server.
2025-02-12 18:34:20.584 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-02-12 18:34:20.584 | DTC Client socket (3) | Shutdown started. Waiting for graceful close.
2025-02-12 18:34:20.684 | DTC Client socket (3) | Socket gracefully closed by remote side.
2025-02-12 18:34:20.684 | DTC Client socket (3) | Closed.
2025-02-12 18:34:32.233 | ESZ24_FUT_CME 1 Min #1 | Reloading chart.
2025-02-12 18:34:32.742 | Mapping ESZ24_FUT_CME to ESZ24. Service code: cme
2025-02-12 18:34:32.742 | Denali Data Feed | Starting real-time market data updates for: ESZ24_FUT_CME (ESZ24). ID: 8 Service code: cme
2025-02-12 18:34:32.742 | Denali Data Feed | Requesting security definition data for: ESZ24_FUT_CME (ESZ24). ID: 8
2025-02-12 18:34:32.742 | Added historical Intraday data request for ESZ24_FUT_CME to the queue.
2025-02-12 18:34:32.742 | Intraday data recording state for symbol ESZ24_FUT_CME is set to download 'Pending'.
2025-02-12 18:34:32.742 | Triggering next historical data download in queue.
2025-02-12 18:34:32.743 | Delaying start of download for ESZ24_FUT_CME.
2025-02-12 18:34:32.861 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESZ24_FUT_CME
2025-02-12 18:34:32.861 | Teton CME Order Routing | Setting external service identifier for symbol ESZ24_FUT_CME to 153
2025-02-12 18:34:32.861 | Teton CME Order Routing | Received security definition for symbol ESZ24_FUT_CME
2025-02-12 18:34:34.251 | ESZ24_FUT_CME[M] 1 Min #1 | Chart data loading complete.
2025-02-12 18:34:43.340 | ESH25_FUT_CME[M] 1 Min #1 | Reloading chart.
2025-02-12 18:34:46.489 | ESH25_FUT_CME[M] 1 Min #1 | Chart data loading complete.
2025-02-12 18:34:53.853 | File >> Disconnect selected.
2025-02-12 18:34:53.854 | Teton CME Order Routing | Waiting for socket receive thread to end
2025-02-12 18:34:53.854 | DTC Client socket (1) | CloseSocket call.
2025-02-12 18:34:53.854 | DTC Client socket (1) | Max send buffers used during socket life: 3
2025-02-12 18:34:53.854 | DTC Client socket (1) | Max send buffer size during socket life: 329
2025-02-12 18:34:53.854 | DTC Client socket (1) | Shutdown started. Waiting for graceful close.
2025-02-12 18:34:53.864 | DTC Client socket (0) | CloseSocket call.
2025-02-12 18:34:53.864 | Denali Data Feed | Disconnected from the server.
2025-02-12 18:34:53.864 | SC Data with Depth | Waiting for socket receive thread to end
2025-02-12 18:34:53.865 | DTC Client socket (2) | CloseSocket call.
2025-02-12 18:34:53.865 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-02-12 18:34:53.865 | SC Data with Depth | Disconnected from the server.
2025-02-12 18:34:53.865 | Delayed Data Feed | Waiting for socket receive thread to end
2025-02-12 18:34:53.865 | DTC Client socket (4) | CloseSocket call.
2025-02-12 18:34:53.865 | Delayed Data Feed | Disconnected from the server.
2025-02-12 18:34:53.865 | Teton CME Order Routing | Disconnected.
2025-02-12 18:34:53.865 | DTC Client socket (4) | Shutdown started. Waiting for graceful close.
2025-02-12 18:34:53.951 | DTC Client socket (1) | Socket gracefully closed by remote side.
2025-02-12 18:34:53.951 | DTC Client socket (1) | Closed.
2025-02-12 18:34:53.966 | DTC Client socket (4) | Socket gracefully closed by remote side.
2025-02-12 18:34:53.966 | DTC Client socket (4) | Closed.
2025-02-12 18:34:54.116 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-02-12 18:34:54.116 | DTC Client socket (2) | Closed.
2025-02-12 18:34:54.455 | HD Request # 7 | Downloading Intraday chart data for ESZ24_FUT_CME to the file ESZ24_FUT_CME.scid. Service: cme
2025-02-12 18:34:54.456 | HD Request # 7 | Download start date-time: 2024-12-20 14:29:59.000000. File last date-time: 2024-12-20 14:29:59.822001
2025-02-12 18:34:54.456 | HD Request # 7 | Using server: ds28.sierracharts.com port 10149
2025-02-12 18:34:54.456 | Socket (1) | Creating socket.
2025-02-12 18:34:54.456 | Socket (1) | New receive buffer size: 0
2025-02-12 18:34:54.456 | Socket (1) | Connecting to IP: 67.214.125.5.
2025-02-12 18:34:54.732 | HD Request # 7 | Setting DTC encoding to Binary VLS
2025-02-12 18:34:54.732 | HD Request # 7 | Sending historical data logon request message.
2025-02-12 18:34:54.880 | HD Request # 7 | Requesting Intraday data. Start date-time: 2024-12-20 14:29:59. Record interval: 0. Symbol: ESZ24
2025-02-12 18:34:54.993 | HD Request # 7 | Decompressing data.
2025-02-12 18:34:55.092 | HD Request # 7 | Receiving Intraday data for ESZ24_FUT_CME starting at 2024-12-20 14:29:59.142000
2025-02-12 18:34:55.092 | Socket (1) | CloseSocket call.
2025-02-12 18:34:55.092 | Socket (1) | Shutdown started. Waiting for graceful close.
2025-02-12 18:34:55.093 | Historical data download thread signaled to stop.
2025-02-12 18:34:55.093 | HD Request # 7 | Received 16 Intraday data records from 2024-12-20 14:29:59.142000 to 2024-12-20 14:29:59.822001 (0.7 seconds. Delay: 54.2 days) and wrote 0 records for ESZ24_FUT_CME
2025-02-12 18:34:55.093 | HD Request # 7 | Completion time: 1s.
2025-02-12 18:34:55.093 | HD Request # 7 | Intraday data download complete for ESZ24_FUT_CME. Unique request ID: 7
2025-02-12 18:34:55.093 | Removing historical data download ID 7.
2025-02-12 18:34:55.093 | Real-time Intraday chart data file updates started for ESZ24_FUT_CME
2025-02-12 18:34:55.093 | Intraday chart data file opened for ESZ24_FUT_CME
2025-02-12 18:34:55.093 | HD Request # 7 | Enabling Intraday chart updating for symbol.
2025-02-12 18:34:55.093 | No download requests in the queue to start downloads for.
2025-02-12 18:34:55.093 | Historical data for ESZ24_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-02-12 18:34:55.193 | Socket (1) | Socket gracefully closed by remote side.
2025-02-12 18:34:55.193 | Socket (1) | Closed.
2025-02-12 18:35:13.066 |
2025-02-12 18:35:13.066 | Teton CME Order Routing | Firm: Dorman/Stage5
2025-02-12 18:35:13.066 | Teton CME Order Routing | Connecting to the server futurestrading14.sierracharts.com. Port 11093
2025-02-12 18:35:13.067 | DTC Client socket (1) | Creating socket. Using TLS 1.2.
2025-02-12 18:35:13.067 | DTC Client socket (1) | New receive buffer size: 0
2025-02-12 18:35:13.067 | DTC Client socket (1) | Connecting to IP: 208.185.224.130.
2025-02-12 18:35:13.162 | Teton CME Order Routing | Network connection to server complete.
2025-02-12 18:35:13.162 | Teton CME Order Routing | Starting socket receive thread.
2025-02-12 18:35:13.162 | Teton CME Order Routing | Sending encoding request to server: Binary VLS. Compression: none
2025-02-12 18:35:13.444 | Teton CME Order Routing | Setting DTC encoding to Binary VLS
2025-02-12 18:35:13.444 | Teton CME Order Routing | Sending logon request message.
2025-02-12 18:35:13.607 | Teton CME Order Routing | Received logon response.
2025-02-12 18:35:13.607 | Teton CME Order Routing | Server Name: SC DTC Server. Build=52100.
2025-02-12 18:35:13.607 | Teton CME Order Routing | Server protocol version: 8. Client protocol version: 8
2025-02-12 18:35:13.607 | Teton CME Order Routing | Successfully connected. Connected to SC DTC Protocol server. Service=cme_ilink3.trading|SymbolSettings=cme_ilink_live.trading.
2025-02-12 18:35:13.607 | Teton CME Order Routing | Trading is supported.
2025-02-12 18:35:13.607 | Teton CME Order Routing | Order cancel and replace is supported.
2025-02-12 18:35:13.607 | Teton CME Order Routing | OCO Orders supported.
2025-02-12 18:35:13.607 | Teton CME Order Routing | Bracket Orders supported.
2025-02-12 18:35:13.607 | Teton CME Order Routing | MarketDepthIsSupported: 1
2025-02-12 18:35:13.607 | Teton CME Order Routing | Connected to server complete.
2025-02-12 18:35:13.608 | No download requests in the queue to start downloads for. | Number times message added: 3
2025-02-12 18:35:13.608 | Updated verified funded futures trading account ending date to: 2025-03-14 18:35:13
2025-02-12 18:35:13.608 | Teton CME Order Routing | Performing query for most recent Order Activity Date-Time.
2025-02-12 18:35:13.638 | Teton CME Order Routing | Requesting historical order activity from server. Start date-time UTC: 2024-12-07 14:06:42.202196
2025-02-12 18:35:13.700 | Updated verified funded futures trading account ending date to: 2025-03-14 18:35:13
2025-02-12 18:35:13.888 | Mapping ESH25_FUT_CME to ESH25. Service code: cme
2025-02-12 18:35:13.888 | Using symbol data fast lookup vector
2025-02-12 18:35:13.888 | Denali Data Feed | Starting real-time market data updates for: ESH25_FUT_CME (ESH25). ID: 1 Service code: cme
2025-02-12 18:35:13.888 | Denali Data Feed | Connecting to the server ds32-2.sierracharts.com. Port 443
2025-02-12 18:35:13.888 | Denali Data Feed | Requesting security definition data for: ESH25_FUT_CME (ESH25). ID: 1
2025-02-12 18:35:13.888 | Added historical Intraday data request for ESH25_FUT_CME to the queue.
2025-02-12 18:35:13.888 | Intraday data recording state for symbol ESH25_FUT_CME is set to download 'Pending'.
2025-02-12 18:35:13.888 | Triggering next historical data download in queue.
2025-02-12 18:35:13.888 | DTC Client socket (2) | Creating socket.
2025-02-12 18:35:13.888 | DTC Client socket (2) | New receive buffer size: 0
2025-02-12 18:35:13.888 | DTC Client socket (2) | Connecting to IP: 67.214.125.4.
2025-02-12 18:35:13.894 | Delaying start of download for ESH25_FUT_CME.
2025-02-12 18:35:14.098 | Trace | Basic security definition symbol settings fields ignored in primary service client. Symbol: ESH25_FUT_CME
2025-02-12 18:35:14.098 | Teton CME Order Routing | Setting external service identifier for symbol ESH25_FUT_CME to 5002
2025-02-12 18:35:14.098 | Teton CME Order Routing | Received security definition for symbol ESH25_FUT_CME
2025-02-12 18:35:14.104 | Denali Data Feed | Network connection to server complete.
2025-02-12 18:35:14.104 | Denali Data Feed | Starting socket receive thread.
2025-02-12 18:35:14.104 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-02-12 18:35:14.227 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-02-12 18:35:14.227 | Denali Data Feed | Sending logon request message.
2025-02-12 18:35:14.513 | Teton CME Order Routing | Received final trade activity snapshot. Count=1. No data. TradeAccount=1948A
2025-02-12 18:35:14.681 | Denali Data Feed | Received logon response.
2025-02-12 18:35:14.681 | Denali Data Feed | Server Name: RealTimeServer.
2025-02-12 18:35:14.681 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-02-12 18:35:14.681 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-02-12 18:35:14.681 | Denali Data Feed | Failed connections: 4
2025-02-12 18:35:14.681 | Denali Data Feed | Waiting for socket receive thread to end
2025-02-12 18:35:14.682 | DTC Client socket (2) | CloseSocket call.
2025-02-12 18:35:14.682 | Denali Data Feed | Disconnected from the server.
2025-02-12 18:35:14.682 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-02-12 18:35:14.683 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-02-12 18:35:14.800 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-02-12 18:35:14.801 | DTC Client socket (2) | Closed.
2025-02-12 18:35:44.466 | HD Request # 8 | Downloading Intraday chart data for ESH25_FUT_CME to the file ESH25_FUT_CME.scid. Service: cme
2025-02-12 18:35:44.468 | HD Request # 8 | Download start date-time: 2025-02-12 18:32:48.000000. File last date-time: 2025-02-12 18:32:48.585000
2025-02-12 18:35:44.468 | HD Request # 8 | Using server: ds32.sierracharts.com port 10150
2025-02-12 18:35:44.468 | Socket (2) | Creating socket.
2025-02-12 18:35:44.469 | Socket (2) | New receive buffer size: 0
2025-02-12 18:35:44.469 | Socket (2) | Connecting to IP: 67.214.125.3.
2025-02-12 18:35:44.663 | HD Request # 8 | Setting DTC encoding to Binary VLS
2025-02-12 18:35:44.663 | HD Request # 8 | Sending historical data logon request message.
2025-02-12 18:35:44.800 | HD Request # 8 | Requesting Intraday data. Start date-time: 2025-02-12 18:32:48. Record interval: 0. Symbol: ESH25
2025-02-12 18:35:44.893 | HD Request # 8 | Decompressing data.
2025-02-12 18:35:45.086 | HD Request # 8 | Receiving Intraday data for ESH25_FUT_CME starting at 2025-02-12 18:32:48.378000
2025-02-12 18:35:45.088 | Socket (2) | CloseSocket call.
2025-02-12 18:35:45.088 | Socket (2) | Shutdown started. Waiting for graceful close.
2025-02-12 18:35:45.088 | Historical data download thread signaled to stop.
2025-02-12 18:35:45.089 | HD Request # 8 | Timestamp of first Intraday data file record written: 2025-02-12 18:32:50.355000.
2025-02-12 18:35:45.089 | HD Request # 8 | Received 3119 Intraday data records from 2025-02-12 18:32:48.378000 to 2025-02-12 18:35:44.182001 (2.9 minutes. Delay: 0.9 seconds) and wrote 3113 records for ESH25_FUT_CME
2025-02-12 18:35:45.096 | HD Request # 8 | Add time&sales data | Remembered last file record date-time: 2025-02-12 18:35:44.182001
2025-02-12 18:35:45.096 | HD Request # 8 | Completion time: 1s.
2025-02-12 18:35:45.096 | HD Request # 8 | Intraday data download complete for ESH25_FUT_CME. Unique request ID: 8
2025-02-12 18:35:45.096 | Removing historical data download ID 8.
2025-02-12 18:35:45.096 | Real-time Intraday chart data file updates started for ESH25_FUT_CME
2025-02-12 18:35:45.096 | Intraday chart data file opened for ESH25_FUT_CME
2025-02-12 18:35:45.096 | HD Request # 8 | Enabling Intraday chart updating for symbol.
2025-02-12 18:35:45.096 | No download requests in the queue to start downloads for.
2025-02-12 18:35:45.096 | Historical data for ESH25_FUT_CME is delayed because connection to main data feed is not present. Current data will be received upon connection.
2025-02-12 18:35:45.183 | Socket (2) | Socket gracefully closed by remote side.
2025-02-12 18:35:45.183 | Socket (2) | Closed.
2025-02-12 18:36:14.670 | Denali Data Feed | Connecting to the server ds25.sierracharts.com. Port 10048
2025-02-12 18:36:14.683 | DTC Client socket (2) | Creating socket.
2025-02-12 18:36:14.683 | DTC Client socket (2) | New receive buffer size: 0
2025-02-12 18:36:14.683 | DTC Client socket (2) | Connecting to IP: 64.152.155.20.
2025-02-12 18:36:14.781 | Denali Data Feed | Network connection to server complete.
2025-02-12 18:36:14.781 | Denali Data Feed | Starting socket receive thread.
2025-02-12 18:36:14.781 | Denali Data Feed | Sending encoding request to server: Binary VLS. Compression: standard
2025-02-12 18:36:14.896 | Denali Data Feed | Setting DTC encoding to Binary VLS
2025-02-12 18:36:14.896 | Denali Data Feed | Sending logon request message.
2025-02-12 18:36:15.355 | Denali Data Feed | Received logon response.
2025-02-12 18:36:15.355 | Denali Data Feed | Server Name: RealTimeServer.
2025-02-12 18:36:15.355 | Denali Data Feed | Server protocol version: 8. Client protocol version: 8
2025-02-12 18:36:15.356 | Denali Data Feed | Logon error received from server: Connection limit exceeded. | MaxConnectionsDifferentDevices = 1, NumCurrentConnectionsDifferentDevices = 2
2025-02-12 18:36:15.356 | Denali Data Feed | Failed connections: 5
2025-02-12 18:36:15.356 | Denali Data Feed | Waiting for socket receive thread to end
2025-02-12 18:36:15.356 | DTC Client socket (2) | CloseSocket call.
2025-02-12 18:36:15.356 | Denali Data Feed | Disconnected from the server.
2025-02-12 18:36:15.356 | Denali Data Feed | Data feed disconnected. Will reconnect in 60 seconds.
2025-02-12 18:36:15.356 | DTC Client socket (2) | Shutdown started. Waiting for graceful close.
2025-02-12 18:36:15.458 | DTC Client socket (2) | Socket gracefully closed by remote side.
2025-02-12 18:36:15.458 | DTC Client socket (2) | Closed.
[2025-02-12 19:40:55]
This is the problem:
Refer to:
Denali Exchange Data Feed: Connections
