Date/Time: Wed, 01 Apr 2026 06:53:14 +0000
Create a tick chart
View Count: 842
| [2025-02-12 09:52:20] |
| Zazzgram91 - Posts: 5 |
I need to create a footprint mode chart with a tick set to 9 i.e. a candle forms only after 9 ticks. I tried to follow your instructions but the result is what you see in the screenshot (and it is wrong). I started by copying the footprint chart I usually use (see photo) and then changed the settings as written in your guide but nothing. https://www.sierrachart.com/image.php?Image=1739353864865.png https://www.sierrachart.com/image.php?Image=173935389724.png |
| [2025-02-12 16:36:23] |
| John - SC Support - Posts: 45398 |
If your issue is with regards to the bars that are on the chart, then that is due to your overlaying the bars from a different timeframe chart. You need to overlay the bars from the same chart so that it is the same bar period.
