Date/Time: Mon, 21 Apr 2025 23:33:11 +0000
Rithmic data issue for Topstep
View Count: 736
[2025-02-12 07:59:32] |
User785723 - Posts: 58 |
Hi The Rithmic data (all Topstep servers) are disconnected for me since a couple of days ago. Please see the screenshot |
Attachment Deleted. ![]() |
[2025-02-12 09:51:58] |
User135243 - Posts: 67 |
You have to upgrade to 2737 or higher and you will see that the Rithmic connection is back
[2025-02-12 15:18:07] |
Sierra_Chart Engineering - Posts: 19290 |
This is definitely not the issue they are having. Most likely they are getting a permission denied error: Rithmic Trading Platform Service: Permission Denied Resolution Procedure Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-02-12 16:03:42
