Date/Time: Mon, 21 Apr 2025 23:30:20 +0000
Volume bars disappeared after unhiding volume by price study
View Count: 143
[2025-02-12 01:10:14] |
NurseG - Posts: 5 |
Hi, I did two things this morning: updated the Sierra chart version, and unclicked "hidden" for a volume by price study for 1bars. I could then see the volume profiles overlayed on the bars however I now do not see numbers bars on any chart book I have numbers bars on (whether I have the volume by price study hidden or not). I have been able to use numbers bars without any problem up to this point. I have tried: -Translating symbol for service -Updating SC version again -Restarted SC -Deleted and redownloaded depth data -Removed numbers bars study and verified I can see the NQ volume bars for enough length of time back then reapplied volume bars study -Removed volume by price for 1bar study -prayed to the stock gods Any help is much appreciated |
[2025-02-12 06:47:04] |
NurseG - Posts: 5 |
I deleted SC and started new with a blank chart book/chart. This is what a chart looks like before the numbers bars study is applied https://www.sierrachart.com/image.php?Image=1739342624179.png |
[2025-02-12 06:47:45] |
NurseG - Posts: 5 |
This is what the chart looks like as soon as I click "apply" after adding the number bars study https://www.sierrachart.com/image.php?Image=1739342700837.png Date Time Of Last Edit: 2025-02-12 06:48:19
[2025-02-12 08:56:22] |
Sierra_Chart Engineering - Posts: 19290 |
Can you tell us, what CPU your computer uses. The specific brand and model number we need to know.
Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-02-12 09:08:14
[2025-02-12 14:15:37] |
NurseG - Posts: 5 |
Apple M2 Max chip, 12 core CPU (8 performance, 4 efficiency) I have my paralells CPU & Memory set to use 10 CPUs, 20gb I do not use this computer for anything else except trading, only other program loaded is Spotify |
[2025-02-12 15:14:04] |
In this case follow the instructions here use the ARM version of Sierra Chart: Software Download: Using ARM Version for Apple M-series CPUs Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-12 18:00:33] |
NurseG - Posts: 5 |
That fixed it! Thanks so much
