Date/Time: Mon, 21 Apr 2025 23:36:11 +0000
Order allocation to accounts clarification
View Count: 102
[2025-02-11 23:00:33]
masedi - Posts: 45
I am using multiple Apex accounts, let's call them A1, A2, A3... Etc.
I configured the allocation to 1x for A1 and A2.
When I trade A3 which was a eval account (so using much higher risk than funded account) I had a couple of bad trades but I found that the trades were copied to A1 and A2 even though A3 was not in the allocation account list.
I understand now that the feature works that if any trade is placed on any account will be copied to A1 and A2.
Is there any way to configure it so the copy only happens between A1 and A2 and NOT if the trade is placed in any other account (eg. A3, A4.. ETC..) ?
The end result I am looking for is that trades only get copied between accounts in the same "group".
The way it works by default is very tricky as there is no concept of master / follower account list and there is no restrictions on which account can copy to The accounts in the allocarion list.
Date Time Of Last Edit: 2025-02-11 23:03:15
[2025-02-12 16:10:13]
John - SC Support - Posts: 39395
There is no support for what you wanting to do.
You need to think differently about how the Order Allocation to Trade Accounts work. You set up the allocation for each Trade Window, which is associated with a specific chart. Therefore, trades that are done on that chart use the order allocation as it is setup. It doesn't matter what Trade Account is selected for that chart at that time, the orders will be copied to the accounts that are defined to be copied to, within the Trade Window (chart).
