Date/Time: Wed, 19 Mar 2025 03:40:15 +0000
Donnée nasdaq futures
View Count: 125
[2025-02-11 22:42:21]
saturne333 - Posts: 2
Bonjour, je vous expose mon projet : je souhaite récupérer un maximum de données en CSV pour le Nasdaq Futures. Je me demande si mon abonnement au Package 5 est suffisant pour cela. J'ai ajouté 39 euros sur mon compte, pensant devoir souscrire au flux complet du CME, mais lorsque j'essaie de l'activer, l'activation est refusée alors que j'ai exactement 39 euros, soit le montant requis. Cordialement.
[2025-02-11 22:57:19]
John - SC Support - Posts: 38782
From Google Translate:
Hello, I will explain my project to you: I want to retrieve as much data as possible in CSV for the Nasdaq Futures. I wonder if my subscription to Package 5 is sufficient for this. I added 39 euros to my account, thinking I had to subscribe to the full CME feed, but when I try to activate it, the activation is refused even though I have exactly 39 euros, the required amount. Best regards.
The reason you could not activate the exchange is because you are on the "Base Standard" package. You can not get real-time data from our Denali Exchange Data Feed unless you are on one of the "Integrated" packages. Refer to the information here:
Description of Service Packages and Pricing: Packages
If you want to change your package, then follow the instructions at the following link:
Sierra Chart Purchase and License Information: Changing Package
But, on any package, you have access to all our historical data as well as our Delayed Streaming Data. Therefore, you can data going back to around 2011 for the E-Mini NASDAQ Futures (NQ) without having to activate an exchange.
If you still do want to activate an exchange, then as noted above, you need to change your package and then setup the data for the CME Group. Refer to the instructions at the following link (noting the requirement that you have a live, funded, futures trading account):
[2025-02-12 12:59:11]
Merci maintenant je ne sais pas quel find symbol je dois exactement choisir pour avoir comme le Nasdaq futur cme et avoir son historique dans sa généralité
Merci beaucoup pour votre aide
[2025-02-12 17:29:36]
Thank you now I don't know which find symbol I should exactly choose to have like the Nasdaq future cme and have its history in its generality
In general, the symbol will depend on the service you are connected to, as each service uses a different symbology.
It looks like you are connected to "SC DAta" according to our servers, in which case the E-Mini NASDAQ 100 Index Futures is the symbol NQ?##-CME where ? is the contract month code and ## is the 2 digit year. Refer to the following for how to use the Find Symbol window:
File Menu: Find Symbol (File)
