Date/Time: Mon, 21 Apr 2025 23:33:09 +0000
ROC text values inside a row in a Numbers Bars Calculated Values table
View Count: 109
[2025-02-11 21:11:54] |
cmack1011 - Posts: 89 |
Could you please direct me on how to create text values for ROC points (average ROC for each candlestick) displayed in a row in the Numbers Bars calculated values table (or inside a custom table if using Numbers Bars CV is not possible)? Thx
[2025-02-11 22:31:03] |
The "Numbers Bars Calculated Values" are set to show only specific subgraphs that are already setup within them. We can add items, but we are generally too busy to do much with it at the moment. The "Numeric Information Graph Reference" allows you to reference up to 10 subgraphs for which you want to display the text value and possibly use the percent coloring. This is the study you want to use and reference the Rate of Change study and subgraph you want. Refer to the following: Numeric Information Reference For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
