Date/Time: Mon, 21 Apr 2025 23:36:09 +0000
Keyboard Shortcut - Bracket order
View Count: 113
[2025-02-11 17:36:07] |
User837393 - Posts: 145 |
Hello, Is there a way to move an entire bracket order (limit entry) with the keyboard shortcut... like manualy chasing the price with tick up or tick down ? Best regards, |
[2025-02-11 17:53:00] |
There are keyboard shortcuts for the following (found under "Trading Keyboard Shortcuts" section): - Non-attached Limit Order Tick Up - Non-attached Limit Order Tick Down - Target Order Tick Up - Target Order Tick Down - Stop Order Tick Up - Stop Order Tick Down For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
