Date/Time: Mon, 21 Apr 2025 23:33:10 +0000
order appears from thin air in Sierra
View Count: 102
[2025-02-11 16:07:04]
User418920 - Posts: 31
Situation is: a 1 DAXm contract order appeared in Sierra out of thin air. By the way, don't know whether it is relevant but this happened after I switched from the 1 hr timeframe to the daily timeframe and back again to the 1 hr timeframe.
I checked the order in my broker screen (see attached screenshot) but there it was not visible. So I thought is probably not a "real" order. When I closed the order in Sierra by flattening all positions, it resulted in a loss (of 3 euro's) in my LMAX broker screen.
LMAX refers to Sierra Chart. Can you fix this please?
Thomas
Date Time Of Last Edit: 2025-02-11 16:11:54
imageScherm­afbeelding 2025-02-11 om 07.51.27.png / V - Attached On 2025-02-11 16:11:46 UTC - Size: 368.29 KB - 27 views
[2025-02-11 17:37:48]
Sierra_Chart Engineering - Posts: 19290
To resolve this, refer to:
LMAX Trading Service: Understanding Position Reporting Problems and Solution
