Date/Time: Mon, 15 Dec 2025 09:11:42 +0000
NISS-SP down again?
View Count: 220
| [2025-02-11 14:35:59] |
| User294671 - Posts: 4 |
Not getting any data this morning.
| [2025-02-11 14:40:04] |
| Sierra_Chart Engineering - Posts: 21843 |
We do not see any problem with this symbol. Select File >> Reconnect Your Sierra Chart account which you have logged into this Support Board with is expired. So we know what Sierra Chart account you are using, go to Help >> Support Board from within the Sierra Chart desktop program and then post in this thread telling us this is done. Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
