Date/Time: Mon, 21 Apr 2025 23:33:10 +0000
seems to be some bugs with drawings
View Count: 94
[2025-02-11 13:51:24]
User594974 - Posts: 35
Hello Sierra Chart friends. I recently updated to the newest version. Seems like there may be some bugs with chart drawings. Here's what happens. I generally overlay chart drawings from other charts onto multiple charts. Then I can manipulate them and delete etc. However, at random times, the chart drawings from other charts simply can't be deleted. No matter what I do, they won't go away. If I remove the chart and then duplicate, all is good. But then have the same issue with more charts. All of this said, I can't put my finger on exactly what it is, and duplicate it over and over again. I'll keep trying to duplicate the issue so you'll know exactly what to look for, but just wanted to highlight that there is really something not quite right with drawings that overlay from others. I generally use lines, horizontal lines, rays, and extending rectangle.
Best,
[2025-02-11 17:32:01]
John - SC Support - Posts: 39395
We are not seeing any issues related to this. We definitely need more information on the workflow you are using that causes it to occur. When you have some additional information, let us know.
