Date/Time: Mon, 21 Apr 2025 23:39:03 +0000
Can't install new version
View Count: 162
[2025-02-11 12:01:58]
User229477 - Posts: 41
I cannot install new version. Message I get is error opening c:\SierraChart 3\SierraChart_64.exe. File error. Windows error code 32. Error encountered with file move
imageScreenshot 2025-02-11 .png / V - Attached On 2025-02-11 11:54:45 UTC - Size: 46.61 KB - 38 views
[2025-02-11 17:29:56]
John - SC Support - Posts: 39395
Refer to the following:
Software Download: Installer Does Not Run After Download is Complete
[2025-02-11 18:31:46]
Sierra_Chart Engineering - Posts: 19290
You need to make sure Sierra Chart is not running when the installer, is installing the files. This is the problem.
When the installer starts, wait one full minute to make sure Sierra Chart is fully shut down after you exit from it.
Date Time Of Last Edit: 2025-02-11 18:32:31
[2025-02-11 18:50:36]
I uninstalled antivirus and it worked.
