Date/Time: Mon, 21 Apr 2025 23:30:17 +0000
Connecting to Rithmic
View Count: 154
[2025-02-11 02:32:20] |
User660392 - Posts: 46 |
Hi , I am trying to connect my Sierra account to Rhythmic but not successfully. After i disconnect & change from Teton to Rhythmic there is not a place to add the settings for Apex. The actions i took : Disconnect than Data trade service than Current selected service (filled with Rhythmic) but where to fill the APEX account? Tnx |
[2025-02-11 04:25:57] |
Sierra_Chart Engineering - Posts: 19290 |
Follow the instructions here: Rithmic Trading Platform Service: Setup Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-13 13:20:17] |
florianh - Posts: 11 |
Hello, I'm adding my question below here since it is related. After connecting to Rithmic Direct, I can see the list of all prop firm servers, I connected and reconnected serveral times to refresh the server list... but the Apex Sao Paulo Server missing, all other Apex and other prop firms are listed properly. I already talked to Apex and they say it must be a Sierra Chart problem, I can also confirm that in Rithmic R-Trader I see the Apex Sao paulo server, just in Sierra Chart is missing. ?
[2025-02-13 15:16:38] |
Sierra Chart does not control that list of servers. It is created by Rithmic. We have no control over this.
