Date/Time: Mon, 21 Apr 2025 23:33:13 +0000
Study Subgraph - Divide/Ratio
View Count: 93
[2025-02-10 23:56:28]
User837393 - Posts: 145
I'm using a the study subgraph - Divide/ratio with the study subgraph above/below bar.
I'm probably doing something wrong, but when I set the input study 1 and 2, in the settings of the study subgraph divide/ratio, to the same variable, I'm not getting 1 for value. Example I'm setting ID0.SG5 for input 1 and 2 and it is giving me some random numbers.
Any help would be appreciated.
Best regards,
[2025-02-10 23:58:50]
Solved... In the setting the offset must be set to 0.
