Date/Time: Mon, 21 Apr 2025 23:33:11 +0000
Advanced Settings Window.
View Count: 124
[2025-02-10 23:53:16] |
User540599 - Posts: 1 |
I was watching one of your user setup videos and the [screen shot attached] chart settings window was shown that includes main and advanced settings. When I click on the f5 or chart settings, I get something completely different.... [also attached] - can you tell me where the main and advanced settings window id moved? im on a PC if that makes a difference. Thanks - mr |
![]() ![]() Attachment Deleted. |
[2025-02-11 00:06:50] |
Sierra_Chart Engineering - Posts: 19290 |
You are using an older version of Sierra Chart. You need to update. Instructions: Software Download: Fast Update Or maybe we misunderstood. Is the Chart Settings window you attached an image of, from your version of Sierra Chart or from the video? Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing Date Time Of Last Edit: 2025-02-11 00:08:22
