Date/Time: Mon, 21 Apr 2025 23:33:11 +0000
Accessing Russell 1000 on Sierra Chart
View Count: 161
[2025-02-10 17:01:30]
User951086 - Posts: 25
I am not able to find the ticker for Russell 1000 futures. I found one for Russell 2000 but not for Russell 1000. Can someone please provide me with the ticker?
[2025-02-10 19:50:08]
John - SC Support - Posts: 39395
There is an E-Mini Russell 1000 Index futures product from the CME Group, if that is what you are looking for. The symbol is RS1. But it is not traded much. Refer to the information from the CME Group at the following link:
https://www.cmegroup.com/markets/equities/russell/e-mini-russell-1000-index.contractSpecs.html
You will find the above symbol under the CME futures on the Find Symbol window.
If you are wanting some other data, then we need to know what you are looking for.
[2025-02-11 00:09:19]
I have already looked the list (attached screenshots too) and I don't find any RS1 ticker. I have also tried to search Russell 1000 in the search box but nothing shows up.
imageCME List 1.png / V - Attached On 2025-02-11 00:08:51 UTC - Size: 229.83 KB - 30 views
imageCME List 2.png / V - Attached On 2025-02-11 00:08:55 UTC - Size: 260.44 KB - 26 views
imageCME List 3.png / V - Attached On 2025-02-11 00:08:59 UTC - Size: 208.19 KB - 27 views
[2025-02-12 23:53:58]
Sierra_Chart Engineering - Posts: 19290
This symbol has been added for Interactive Brokers.
