Date/Time: Mon, 21 Apr 2025 23:36:06 +0000
v2739 - DPL bug
View Count: 191
[2025-02-10 13:22:01]
fried4104 - Posts: 75
Updated to prerelease, and there's an PNL bug, winners are shown as losers in DPL on chart and on the Trade Window.
Trade log and statistics are working fine though.
Thanks.
Date Time Of Last Edit: 2025-02-10 13:22:35
[2025-02-10 16:26:15]
John - SC Support - Posts: 39395
It sounds like your fills are not aligned properly. Refer to the following which will apply even though it is about Daily Profit/Loss:
Help With Daily Profit/Loss Value
[2025-02-10 17:55:52]
Sierra_Chart Engineering - Posts: 19290
Yes this is simply an issue with the starting Date-Time of the order fills in the chart. There might also be a missing fill from that date-time.
[2025-02-11 06:42:01]
Thank you, will look into it.
[2025-02-11 14:47:58]
Followed your suggested links, tried everything, compared them 1:1 with the other working charts, the only solution that worked was to duplicate the buggy chart.
Duplicated chart showed the correct DPL like all other charts, so I closed the original.
All good now, I don't know what the problem was but Im glad I found a solution.
