Date/Time: Mon, 21 Apr 2025 23:33:08 +0000
market structure MSL / MSH
View Count: 200
[2025-02-09 20:05:40] |
lservin29 - Posts: 67 |
is there a way to draw an extension line toward the right side y-axis to illustrate the structural break at the point of indicator (study) execution
[2025-02-10 16:11:42] |
We think the following is what you are looking for: Color Bar Based on Alert Condition: Creating Extension Lines for Another Study For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
[2025-02-10 17:44:22] |
i tried this, i guess i dont understand the syntax to use.
[2025-02-10 19:57:08] |
Please give us a specific example of what you are trying to do. We need to know the study you are using and what you are referrign to as a "structural break". An image with markups indicating what you want would be helpful, just make sure the image is very clean with just the indicator and the bars you are wanting on it.
[2025-02-10 22:14:22] |
the study being used = Market Structure MSL/MSH see image and nots on image for desired results thanks maybe the study mentioned above could be developed further, to perform the request...maybe. |
[2025-02-11 14:51:56] |
There is no image attached. You would use the Color Bar Based on Alert Condition as referenced above. The alert condition for where a Market Structure High exists would be the following: =ID1.SG1 In this case, for the "Color Bar Based on Alert Condition" you would need to set the Input for "Output When Condition True" to "Use Input Data" and then for the "Input Data" set it to the bar value you want to use (most likely Open or Close, but it is up to you). For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
