Date/Time: Mon, 21 Apr 2025 23:36:07 +0000
One VbP profile for current RTH and previous ETH
View Count: 171
[2025-02-08 13:58:01]
User749595 - Posts: 19
Hello!
I am using a TPO chart. Is it possible to configure a VbP study so it only shows one VbP profile for the current RTH session and one VbP profile for the previous ETH session and no other VbP studies?
[2025-02-10 15:35:44]
John - SC Support - Posts: 39395
To start with, refer to the following example for how to display a Volume by Price profile on a TPO chart that is separate from the TPOs:
Volume By Price Study: 30 Minute Volume Profile at End of TPO Profile Chart
Getting the Current RTH session is not difficult, just follow the example at the following link, being sure to set the profile to be independent from the TPO:
Volume By Price Study: One Volume Profile at End for Day Session
The ETH for the previous session gets difficult. Are you really looking for the Evening Session from the previous day or are you looking for the most recent evening session?
If you are looking for the previous sessions Evening Profile (i.e. today is Wednesday at 10:00, then you are wanting the Evening Session that starts at 17:00 on Monday night through 08:29:59 on Tuesday morning) then you would need to use a profile option that includes the Date and Time for the start and then either a fixed amount of time or an ending Date and Time. This will require that you update the date every date.
If you are looking for the evening profile of the current session (i.e. today is Wednesday at 10:00 and you are wanting the Evening Session that starts at 17:00 on Tuesday night through 08:29:59 on Wednesday morning) then you would use the same setup as you did for the Day session above just setting the Start and End times.
[2025-02-10 16:37:25]
Hi John,
Thank you for the reply! I am looking for the evening profile of the current session.
[2025-02-10 16:59:57]
Then follow the example here:
Volume By Price Study: One Volume Profile at End for Evening Session
