Date/Time: Fri, 30 Oct 2026 16:03:39 +0000
[User Discussion] - Count time when bars move 20 points
View Count: 539
[2025-02-08 06:07:22]
User488241 - Posts: 44
I am using spreadsheet study to try to accomplish the following.
add up previous E (last value) column until it reaches 20 or -20.
Take the same relative cells in the bar duration value of numbers bars and sum those up.
Plot that with a moving average.
I'm having an issue with trying to execute the logic of it in spread sheets.
ie.
if(sum(e3:e(unknown cell value))=or(20,-20), (unknown cell value), 0)
take the unknown cell value and use it to sum the time values up.
Thank you if you have any tips!
[2025-02-08 06:08:32]
Oh i wanted to clarify that i use volume bars and not time bars.
[2025-02-08 20:03:38]
figured out a ghetto way around it. Made a 20pt range chart and am plotting the bar duration.
