Date/Time: Mon, 21 Apr 2025 23:36:11 +0000
No data for a custom calculated system after switching data service
View Count: 93
[2025-02-07 17:23:36] |
Sierra123 - Posts: 27 |
I am trying to test the use of the Denali data feeds, so signed up for more feeds, then switched data service from Interactive Brokers to Sierra Charts service. All is back to normal with the exception of my custom calculated symbol. I have one simple FSC --- 1*{TICK-NASDAQ}+1*{TICK-NYSE} The message log has been sent. Thanks |
[2025-02-07 18:33:54] |
Sierra_Chart Engineering - Posts: 19290 |
You need to set up this custom symbol for the particular current Data service you are using. It is not set up as a custom symbol. Instructions: Custom Calculated Symbols: Instructions Sierra Chart Support - Engineering Level Your definitive source for support. Other responses are from users. Try to keep your questions brief and to the point. Be aware of support policy: https://www.sierrachart.com/index.php?l=PostingInformation.php#GeneralInformation For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
