Date/Time: Mon, 21 Apr 2025 23:36:08 +0000
AutoScroll setup so the current price bar is always on the screen
View Count: 125
[2025-02-07 16:56:11] |
droz1990 - Posts: 1 |
How do i set up autoscroll so the chart moves with the current price bar? Ive clicked chart end, but price still moves off screen if i dont drag it. Is there a setting that i need to change?
[2025-02-07 18:51:44] |
We think you are referring to the following: Chart Scale and Scale Adjusting: Constant Range Scale Modes >> Re-Center To The Last Price On Every Update But look through the various scaling options on the above page and see if there is something more to your liking. For the most reliable, advanced, and zero cost futures order routing, use the Teton service: Sierra Chart Teton Futures Order Routing |
