Date/Time: Tue, 22 Apr 2025 02:27:38 +0000
how to differentiate trades from replay sierrachart
View Count: 105
[2025-02-07 10:21:26]
User361939 - Posts: 167
Please help me understand:
how to differentiate trades from replay sierrachart from those taken on SIM but in real time? In trade activity log they both appear as "SIM". Is there a place I can check it?
Regards
[2025-02-07 14:42:43]
Sierra_Chart Engineering - Posts: 19290
Internally they are marked as to whether they occurred during a replay or not.
The only way you can see this is to select the order fill line in the Trade Activity Log for the particular fill and select Edit >> Edit Trade Activity Entry.
Look at the Is Chart Replaying option.
[2025-02-07 16:28:08]
John - SC Support - Posts: 39395
Our recommendation would be to use a different simulation account during replays, so you can easily differentiate. You can set the number of simulation accounts you have available via the following setting:
Global Trade Settings Windows: Number of Simulation Accounts (Global Settings >> General Trade Settings >> General)
